| MINI2 Newbie Join Date: Dec 2006 Local Time: 11:57 PM
Offline | Rattling noise fromInstrument cluster on engine start A rattling noise from behind the main instrument cluster can be heard on most engine starts. It sounds a bit like a noisy actuator opening a valve in the heating/cooling system. The car is sixteen months old and has only covered 3000 miles. Has anyone else had this problem? |
| MINI2 Newbie Join Date: May 2004 Local Time: 11:57 PM
Offline | Hi, next time you start it look at the guages (fuel in paricular). If they "judder" before rising to the correct position then you have the same characteristic as me! I've no idea what it is but it doesn't seem to cause a problem. The only connection I can make is that it is similar to the effect you get when re-setting the ECU memory (which I did after reading about the "learning" aspects of the ECU and loading the MTH chip programme) . If anyone knows the root cause please let me know. |
Offline | Hi Brakedwell, Just a thought - any chance your ECU has ever been re-set? Also, my fuel guage sometimes plays up. It stay on empty and the range on the trip computer reads zero but it slowly sorts itself out, sometimes after a re-start. I've read that this is a "common" fault with the fuel gauge sender unit but so intermittent that I've not bothered to take it to the dealer (they can't do a thing unless it's broke!). Mines a Feb 2004 Cooper. Could it be related to the problem? Anyone else have any ideas. |
Offline | Morning Herbiea. When I moved the Mini One this morning the first start was normal, but the noise re-occured when I returned it to it's parking place in front of the garage ten minutes later. The temperature and fuel guage needles didn't move off their stops until the rattling noise stopped. (Two or three seconds). I am going to contact the dealer in the new year. It could mean a new instrument cluster, which might not be a bad thing as the clock has gained a minute a day since the car was new in Sept 2005! |
| | #6 (permalink) |
Offline | Brakedwell, thanks for the up-date - sounds exactly the same "fault" as I have. Let me know what the dealer does to fix it as my 3 years is up in 6 weeks. If it's serious I'll get mine booked in (try to avoid it as my dealer is not that local and it's a bit of pain). Have a good Christmas and keep on braking! |
| | #7 (permalink) |
| I Love My MINI! Join Date: Mar 2006 Location: Hertfordshire Local Time: 11:57 PM
Offline | Most times I start my 03 MCS, my istrument cluster makes a noise. The dials rattle and then thhe engine starts and thhe dial guage moves up. Its very odd and started doing it when it started getting colder. ![]() |
| | #8 (permalink) |
| MINI less. Join Date: Jan 2004 Location: Poole, Dorset.UK Local Time: 11:57 PM
Offline | Mines been doing this for well over a year..on start up the speedo needle jumps on the sport for 2 secs..damn annoying, but loads of MINI's do it and local stealer said it was normal and it was the ecu self testing everytime it does it....whether thats a load of twaddle or not who knows..just another MINI mystery. I'm being tempted back to a MINI.... |
| | #9 (permalink) |
Offline | I took it to the Dealer today, but since I filled the tank on Boxing Day the needle stays on the full position during the engine start, rather than dropping to the bottom of the guage while the starter motor is turning. I can still hear a slight whirring noise as the needle rises up the scale when powered by the battery. There is also an issue with the clock, which gains three minutes a week, so the dealer has ordered a new instrument cluster which should cure both snags. |
| | #10 (permalink) |
| MINI2 Newbie Join Date: Nov 2003 Location: Essex Local Time: 11:57 PM
Offline | Sounds similar to both the MINI's i have had, it get worse in the winter & in my case seems to be caused by the battery being under a heavier load when starting a colder engine. As well as the needles resetting to 0, it also causes the climate control display to go blank and its relays to chatter as well. I guess an easy to check is to charge the battery then try a cold start, which seemes to work for me. I guess 3 years old is about right for a battery to start showing signs of age. Whilst trying to diagnose the problem i tried a couple of dealers & non seem to have a clue as to the problem. Generally its worse if the car has been left standing for a few days or weeks. |
| | #11 (permalink) |
Offline | Iain, When I first phoned the dealer about the fuel guage problem they said it could be a low battery, so I went out and connected a sophisticated battery charger. The initial charge was less than one amp and this dropped to zero within 15 minutes. The car is only 14 months old so the battery should be in good nick. The dealer didn't quibble about the clock due to the build date of the car. I suspect there are a lot more MINIS out there with hyper-active clocks! |
| Rattling noise when engine cold | berty | 2nd Gen Faults & Fixes | 14 | Feb 17th, 2008 06:05 PM |
| Rattling noise around the headrest | Suj999 | Faults & Fixes | 8 | Aug 15th, 2007 02:52 PM |
| Rattling start/stop button | tiger333888 | 2nd Gen Faults & Fixes | 0 | Jan 10th, 2007 09:21 AM |
| Engine noise on start up | liznewman | MINI Cooper S | 11 | Jul 29th, 2006 05:13 PM |
| Rattling noise on Shifter | holyjoe | Faults & Fixes | 2 | Jul 31st, 2005 04:27 AM |
