Visit Out Motoring!
Tags: , ,
Old Jan 15th, 2007, 05:17 AM   #1
cpark
cpark's Avatar
Local Time: 03:17 PM
Cracked Windshield
Went down to the garage yesterday morning and found a crack in the windshield that I hadn't seen before. It was a relatively cold night for California with a low of 26F and the crack is on the inside of the screen and looks to have started up in the frame and moved down. No sign of rock hit or other impact on the outside. Totally baffled. Has anyone else run into this problem and given the lack of flying rock or bat to windshield it seems that the warranty might take care of this for me? Any thoughts?
Old Jan 15th, 2007, 06:27 AM   #2 (permalink)
kezman50
Local Time: 11:17 PM
United-Kingdom
Annoying I know. The chances are it is from an impact though, rather than anything else.... and that you simply do not recall the event. The mini screen by its nature, sits more upright than most other modern cars and to a fair degree therefore, tends to receive more force from a projectile!
I'm of the opinion that a windscreen/shield is weaker at the edge of the glass, so it follows that the further away an impact is from the center area, the more likely it will result in a crack.
On one of my mini screens, I took a stone, obviously pinged if you like, from another car, round about where my head would be. Examined the car that night, "phew, got away with that". Second day no problem...it was only the third day after, a crack appeared. So it just goes to show, the result can sometimes be far removed from the event, along with sudden changes in temp etc etc,
Old Jan 15th, 2007, 06:48 AM   #3 (permalink)
KPKalle
Knight of the Round Table
KPKalle's Avatar
There's lots of cracked windscreen issues in the Faults & Fixes forum. Try searching
Global Moderator
England Male View KPKalle's Laser Blue & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Jan 15th, 2007, 03:14 PM   #4 (permalink)
cpark
cpark's Avatar
Thanks for the tip, it appears that this cracked windshield issue is more common than I ever would have expected. Oh well, time to call the dreaded service manager.
Old Jan 16th, 2007, 04:06 PM   #5 (permalink)
minimike7
Minitastic
minimike7's Avatar
Send a message via MSN to minimike7
I had the same problem, going around the m25 to heathrow, went to pick up my mate from the terminal and the front windowscreen was fine, come back and a massive 5cm crack appears from the far right edge, as said above by kezman50 as its so upright its weaker and the closer the impact to the edge the less the chance it can be fixed, i have had a new window from autoglass on my insurance and its never been the same, i find you can really hear the windnoise now like having a windo open all the time, then again i only had the car with the old window for 4 days could only happen to a brand new car
Old Jan 16th, 2007, 04:35 PM   #6 (permalink)
cpark
cpark's Avatar
its pretty wild having the widow crack the way it does. my crack is on the inside of the car (tracked it with a ball point pen) and seems grows every morning the temp falls below freezing. I am crossing my fingers for some sun.
Old Jan 18th, 2007, 10:25 AM   #7 (permalink)
miha
miha's Avatar
Send a message via Yahoo to miha
Hi: in 103.000 km, I cracked 3 windows,... I am on 4th now,... :-)
Luckily they are insured,...
BR : Miha
Slovenia View miha's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 18th, 2007, 12:17 PM   #8 (permalink)
DOT191
Local Time: 06:17 PM
We must be very Lucky. We own a 2003 MC. Bought it New. Took delivery on 03/01/03. Are Windshield is Original. No Cracks or Serious pitting. Live in NH & Drive in Snow , Sand & Salt.
Cracked Windshield paula carolan Faults & Fixes 29 Apr 11th, 2006 10:00 PM
'05 S Cracked Windshield relluc MINI Cooper S 6 Nov 3rd, 2004 04:20 PM
cracked windshield Allgreen Faults & Fixes 24 Feb 17th, 2004 09:51 AM
cracked windshield ? MINIMEDE General Discussion 0 Oct 24th, 2003 08:19 AM
cracked Windshield spaceseal Faults & Fixes 0 Jun 29th, 2003 04:16 PM
