Old Feb 16th, 2007, 06:37 PM   #1
Lawrothegreat
Mini Design Philosopher
Lawrothegreat's Avatar
Local Time: 04:13 AM
Rear Brakes
My car has now covered 41,000 miles.
The rear brake pads were replaced at 25,000 miles.
The car is still on the original front brake pads, and front and rear discs.
I'm told the rear brake pads need replacing again!
I'm happy with the mileage covered before replacements, but I find it odd that I'm through two sets of rear brake pads before the front pads and discs, and the rear discs?
Not being completely familiar with the electronics systems, is it possible to have an overactive EBD system causing more aggressive rear braking?
Has anyone else experienced this problem?
Old Feb 16th, 2007, 08:52 PM   #2 (permalink)
jojoq
Local Time: 03:13 AM
Scotland Mini Brake Pads/Discs
Expensive day all round.
Not only has the alternator & power steering pump failed at the same time.(the dealer apparently never heard of this happening before)
Strangely the battery has also been wiped out, which implies the alternator may have overcharged & took everything out.
I would love an understanding Mini dealer to explain.
the rear pads/discs/ callipers need replacing. The front pads & discs also need replacing which is strange.
The car has done 58k & never needed brake pads ( one careful lady driver).
The discs have actually corroded away, and the rear callipers are not releasing, which is probably your problem.
The dealer is totally unsympathetic and said I should have bought extended warranty & at £84.00 an hour labour rate, they are having a field day.
Having been a VW workshop controller previously, I can't believe the difference in how a Mini dealer handles its customers, than again the mini is a low earner for BMW dealers.
Rant over, anyone got MINI customer services number in the UK?
Rear Brakes vanos Faults & Fixes 1 Nov 10th, 2006 11:16 AM
Noisy rear brakes - need your help please! Peartreeproductions Wheels, Tyres & Brakes 3 Aug 30th, 2006 07:49 PM
Rear brakes after wash.. Mini Me GB Maintenance & MINI Care 9 Feb 10th, 2005 05:20 PM
Rear brakes changing help required FONTAL Maintenance & MINI Care 1 Oct 29th, 2004 08:27 AM
Rear brakes vpr Maintenance & MINI Care 8 Jun 5th, 2004 09:35 PM
