Visit Out Motoring!
Old Feb 26th, 2007, 12:00 PM   #1
stevenrollo
Local Time: 07:42 AM
United-Kingdom Headlight level problems
Hello,
Please can anyone explain and help my poorly mini
From time to time when I'm driving at night i notice my headlights are pointing down to the ground making driving visability very poor. As i try to re-adjust them using the level switch nothing happens.
This is a intermittent problem and only happens when it feels like it.
Any ideas?
thanks
Steve
Old Feb 26th, 2007, 12:07 PM   #2 (permalink)
ONED
SUCKIN DIESEL!!!!
ONED's Avatar
Faulty motors!.......we had both headlamps replaced on our last car!
United Nations Male View ONED's Nightfire Red & Black 2nd Gen MINI Cooper Diesel Profile   Reply With Quote
Old Feb 26th, 2007, 12:16 PM   #3 (permalink)
stevenrollo
Hey thanks
Well that was my last resort to go to the MINI dealership. I did have an idea to set them up then disconnect the leveling switch wires to stop from happening again. However i thought could have affects to the start up of the ignition of the car as you can hear the lights aligning themselves as the car is started.
Hope there can be a cheaper option.
Old Feb 26th, 2007, 12:21 PM   #4 (permalink)
ONED
SUCKIN DIESEL!!!!
ONED's Avatar
is the car under warranty?
Old Feb 26th, 2007, 12:24 PM   #5 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
Is it lowerd or anything...as this can cause the xenons to be way out (mind you said the wheelie thing, so I guess that means they are halogens)
Old Feb 26th, 2007, 07:35 PM   #6 (permalink)
stevenrollo
mini is not lowered or modified in anyway, they are the basic mini lights no flash blue lights here lol
Happened again tonight when on way home, thinking could be a fault wire somewhere cause when they do they work they work great! you can realign them using the switch near to the steering wheel to adjust them higher or lower.
Dont want to change light units as could be expensive and i wanna fit a cooper s body kit with centre exhaust an all that.
Guess i have to put u with the dodgy lights,
cheers
Old Feb 27th, 2007, 11:30 AM   #7 (permalink)
vigilante
Whats this Datsun?
vigilante's Avatar
Send a message via MSN to vigilante
Hey up Steve!
My car has recently developed this fault to from shutting the bonnet a bit vigorously in a whilst hissy fit...d'oh!
There is another thread on this problem (should be near this one now in faults forum and has a few DIY fixes to try.
Mini Mania 08 13th July 08 - Durham - Its mahoosive!
North East Mini Club - More Mini Fun in the North East!!
Old Apr 12th, 2007, 12:01 PM   #8 (permalink)
scruffy1806
Local Time: 04:42 PM
Australia mini mechanic said you can disconnect self leveling
Quote: Originally Posted by stevenrollo (original)
Hey thanks
My drivers side headlight points to the ground, checked with mini mechanic today...he said it is possible to disconnect the self leveling with no effect on ignition, he was vague about WHAT to disconnect though.
for $1700 AUD for a replacement headlight I will be doing some research on how to disconnect self leveling.....if anyone knows how...it will be appreciated, thanks
Australia   Reply With Quote
Old Apr 27th, 2007, 04:35 AM   #9 (permalink)
roni
Local Time: 02:42 AM
you need headlight assembly for sure
Old Sep 3rd, 2008, 12:18 PM   #10 (permalink)
stevenrollo
Headlight leveling problems
Sounds like a plan,
Going to Tinker about under the bonnet to see how to disconnect the self leveling motors. Once set at the height then will mae the cut.
Will add on later the results... lol
Any other ideas please shout up!
Headlight Washer Problems Gaz-24 Faults & Fixes 5 Dec 4th, 2006 09:45 PM
AUSTRALIAN HEADLIGHT PROBLEMS - reply here. cityclinic Faults & Fixes 22 Nov 10th, 2004 11:34 AM
Headlight Level control basskiwi MINI One 5 Jan 20th, 2004 12:55 PM
Coolant level right on min level rainbowdreamer Faults & Fixes 2 Aug 24th, 2003 04:06 PM
Headlight level switch rhardaker Interior & Ice 1 Jul 30th, 2003 07:06 AM
