| MINI2 Regular | Engine Management Hi there I have just finished fitting my new manifold and now the engine managemtn light remains on can anyone help or has nayone experianced this before? Many Thanks Phil |
| 003 On a Mission Join Date: Jan 2003 Location: Cabbage County Local Time: 05:34 PM
Offline | Well I hope so Mine has been off then back on, had a reset at the dealers. lasted about 1000 miles then came on gain So had a new oxy sensor fitted, light stayed off for about another 1000miles then came back on Now trying some suggestions made to me. New seal on oil filler and new petrol cap the cap sealwas cracked so fingers crossed it may cure it, althuogh not holding out much help ![]() |
| | #7 (permalink) |
| MINI2 Sponsor Join Date: Mar 2006 Local Time: 05:34 PM
Offline | with a new manifold fitted, if it is a performance one, and it works, more air flow is produced via the exhaust, this causes the o2 sensor to think there is a fault in the cat as the flow exceeds the factory limit, the same is true if the sensor detects too little flow and the light comes on to tell you the cat is blocked/faulty |
| | #8 (permalink) |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 05:34 PM
Offline | It will either go off on its own or you can reset the ECU and re-teach it on the new manifold. There a how to on ECU reset either here or NAM or motoringfile. |
| | #10 (permalink) |
| MINI2 Regular Join Date: Jan 2007 Location: Eastern USA Local Time: 12:34 PM
Offline | I am no expert in MINI O2 sensors, but my experience with other cars, including my current XJ6 with 4 O2 sensors and four converters tells me that these sensors do not monitor gas flow, only O2 content in the flow. The only sensor I know of that could detect an exhaust restriction is a manifiold absolute pressure sensor, but the MINI does not have one. It is possible that the problem you are having may be related to a gasket leak or other mainfold leak either in the intake or exhaust, which will contaminate the airstream and trigger a fuel trim problem, possibly setting off the light. |
| Help - engine management lite came on | Friendy | Maintenance & MINI Care | 3 | Sep 22nd, 2007 04:25 PM |
| Engine Management Light | io1901 | 2nd Gen Faults & Fixes | 3 | Jul 17th, 2007 03:16 PM |
| Engine management light has come on?? | fozworth | Engine & Drivetrain Tuning | 23 | Apr 1st, 2007 07:33 PM |
| Engine Management Adaption | barrie74 | General Discussion | 7 | Jan 14th, 2004 02:47 PM |
| engine management | jlm | Engine & Drivetrain Tuning | 1 | Dec 18th, 2002 10:55 PM |
