Old Apr 8th, 2007, 04:03 AM   #1
jksgoh
jksgoh's Avatar
Local Time: 09:09 AM
Angry coolant level going down
hey,
may sound like a noobie q(it actually is a noobie q lol)
just wondering, how fast is the coolant level meant to go down in the minis??? mines a r50 btw.
i kept going down quite often, so i asked teh bmw guy and they ended up replacing the water pump as it was "leaking". but, it still goes down below min level, and the ba**** just keeps telling me to add water.
could it be another leak?
i'm bringin my car in for airbags (again) so im going to bring the coolant problem up with them. is there any tests or nething that they can do to find out where its leaking (if it is)?
thanks
Australia   Reply With Quote
Old Apr 8th, 2007, 03:15 PM   #2 (permalink)
S33BBY
Local Time: 12:09 AM
There was a problem with the coolant bottle leaking. Have you had this replaced? That's probably the issue.
JCW Sound Kit | H/K | Sat Nav | SS+ | Xenons | 17" Anthracite R90s | Goodyear Eagle F1 GS-D3s | ...
United Kingdom Male View S33BBY's Hyper Blue & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Apr 9th, 2007, 12:01 AM   #3 (permalink)
jksgoh
jksgoh's Avatar
by coolant bottle you mean the one in the engine bay? dont think its ever been replaced. is there a way to check if its leaky? (like should i see some residue or something in a particular spot??
thanks
Old Apr 9th, 2007, 10:20 AM   #4 (permalink)
S33BBY
Yep, the one in the engine bay. If you have a little search, you'll find loads of threads about it that should help you out.
Old Apr 13th, 2007, 12:47 PM   #5 (permalink)
oldmots
Local Time: 07:09 PM
It is possible that after the pump was replaced, the system was not properly bled. As the system slowly tries to bleed itself, the air is replaced by coolant and the level drops. Also, if the heater valve was not opened prior to refill, the heater could have an air lock, requiring bleeding as well. The standard Mini has three bleed points that need to be opened until bubble free coolant comes out. One is on the big upper hose, one is on a heater hose next to the battery and one is on a coolant pipe at the left end of the engine from the drivers point of view. Prior to coolant fill, the ignition needs to be turned to position 1, the heater turned to high temp and the blower to low, this opens the valve, then the bleed points are opened and the coolant can thenbe poured in, closing each bleed as the coolant flows out of it.
Coolant level ? fraujmj Faults & Fixes 3 Jan 27th, 2006 05:51 PM
coolant level - please help matt21 Faults & Fixes 3 Oct 22nd, 2004 04:25 PM
Coolant level newminimark Faults & Fixes 18 Oct 14th, 2003 07:55 PM
Coolant level right on min level rainbowdreamer Faults & Fixes 2 Aug 24th, 2003 04:06 PM
Coolant level. KenL Faults & Fixes 9 Nov 29th, 2002 06:02 AM
