| MINI2 Master Join Date: Aug 2003 Location: South Florida Local Time: 07:08 PM
Offline | Annoying clutch pedal friction noise/feel Greetings everyone.... I am having a seemingly annoying problem with the clutch pedal of my '05 R53 with 23K miles..... When the car is cold (Has seated overnight) and I press and release the clutch pedal with the engine still turned off, the pedal feels perfectly fine. After I start the engine and drive the car for 5-10 minutes, I begin to feel what could better be describe as "Friction" when pressing and releasing the clutch pedal. There is a faint squeak noise, like "Rubber against rubber" type of noise/feel. It also feels as it some moving part in the pedal assembly had no lubrication. The pedal rubber friction comes and goes, but this week its been specially annoying. Other than the friction noise, the clutch seems to be working fine. I have not noticed any differences in pedal travel, Press/release action or engagement point. I am able to shift up and down perfectly fine. This problem is completely different from the "squeal" noise reported in other threads when coming out of first gear. This is not that problem. I don't have any transmission noises, other than, the pedal "dried rubber" feel. Any ideas? Yesterday I grabbed a can of WD-40 lubrication oil and attempted to spray the clutch pedal release spring, which is located high up behind the dashboard (It helped some). However, I suspect that the problem could be coming from the clutch pedal bushings in the pivot connection point where the pedal connects to the pedal holding assembly, again behind the dashboard. I know that this problem was very common in 1990's E36 BMW 3 series and the factory clutch pedal bushings were commonly at fault. I don't think the problem has anything to do with the slave cylinder (My clutch is not getting stuck) or the throw out bearing. If it is not the clutch pedal holding bushings, could it be a sign that the clutch assembly itself is/has worn out? I am trying to avoid a trip to the dealer just for this, but if the noise continues I have no much of a choice. I am open to ideas/suggestions/comments Has anyone had this problem? '02 Cooper CVT PW/B '05 MCS CR/W |
| GP 06 MCS 0380 | I had this problem on my 01 cooper and 04 cooper S. Both occassions dealer tried greasing up the bushings on the clutch pedal linkage and replacing them, but, it inevitably came back, and resorted to changing the clutch which cured it over last summer and the winter. But this last few weeks with the dry spell weve had it seems to be coming back, but not to the extend of before. Its especially bad in slow traffic where you are constantly adjusting the clutch. Ideally if I was engineering the car, I would have used some ball bearings instead of bushes on the clutch linkage. ![]() |
| MINI2 Regular Join Date: Oct 2004 Location: Fremantle Local Time: 07:08 AM
Offline | Hi there, I have a 02 MCS (I bought it December 2006). I wouldn't say my clutch has a problem, but reading this thread maybe it has. I always considered it to be quite heavy, especially driving the MCS after driving my wife's Subaru Outback. I would describe it as heavier than most modern cars and sometimes it's not as smooth as it should be. It's a bit like a seized clutch cable, but of course this couldn't be the case because it is a hydraulic system. As mentioned by CooperS4us, I would suspect it to be dry or un-lubricated bushings on the clutch pedal mechanism. I've been meaning to check it out someday...maybe this weekend. Can I ask PmP whether the lubrication of the pedal assembly helped by the dealer solved the problem initially (but got bad after some time), or was it the change of clutch that made the big difference? Cheers, Dave |
| | #7 (permalink) |
Offline | Thanks Journeyman. It's strange that those that have sprayed WD40 or similar on the clutch pedal mechanism (under the dash) say that the clutch feel improves for a little while. To me this implies that the pedal mechanism is at fault (dry bushes or lack of lubrication). My clutch is heavy (a bit like using a race clutch). I doubt a flywheel change would help. |
| | #8 (permalink) |
Offline | Thanks everyone. This confirms my suspicions about dried up bushings in the clutch pedal assembly. Seems like the same problem that plagued the E36 BMW 3 series and some M coupes and roadsters. I have been driving the car for the last couple of days and the clutch feels a little better in terns of the friction feel, so I have decided to cancel Monday's dealer service appointment. The car otherwise drives great and the shifting action is good as ever. I don't really want my dealer to mess around with my factory installed clutch unless they absolutely have to (They have very good techs, but still). I am going to play it by ear and see if it gets worse over the next 3 months (When my second scheduled dealer maintenance will take place) or if it stays the same. My first '04 MCS did the same thing and never bother to get it looked at and the car drove fine until I sold it. The R53 clutch is indeed heavy, even more so when compared to the R50 clutch (In both Midlands and Getrag versions). It is a known fact that the E36 3 series and M Coupe/Roadster stock clutch pedal bushings are pure rubbish and most of these owners have purchased much better quality aftermarket bushings. I will take a peek underneath the dashboard this weekend and see if I can grease/oil the moving parts and pivot point of the clutch pedal. That will save me an unecessary trip to the dealer and downtime for my MINI. If anyone has encountered this annoyance and has been able to do a DIY repair, please post it here. We will love to hear from you. '02 Cooper CVT PW/B '05 MCS CR/W |
| | #10 (permalink) |
Offline | Does anyone know how to remove the driver's side bolster plastic panel (US) or the parcel tray? Since the pivot connecting point for the clutch pedal is high up behind the dashboard I am trying to get to it without having to peek and reach from way under the dash. '02 Cooper CVT PW/B '05 MCS CR/W |
| | #14 (permalink) |
Offline | I was driving my MINI quite a bit over the weekend and I was able to pay more attention to the way the clutch feels. As i said before, my R53 MCS clutch seems heavier than a modern car should be (likened it to a classic Mini race clutch). Pressing the clutch pedal slowly I can feel a jerkiness. It feels a bit like a clutch cable that needs lubrication, but of course the MCS uses a hydraulic clutch. I don't think the resistance is in the slave cylinder because I don't think the jerkiness would be transmitted so well through the hydraulic system. This leaves the actual pedal mechanism. My guess is that there are nylon bushes on the clutch pedal pivot and these bushes need some grease. It wouldn't be the first time a MINI was lacking grease (seat tilt mechanism comes to mind). Spraying WD-40 in the general area of the pivot seems to have helped some people, for a little while. I'm moving house (to house with no garage) so I'll have to live with the clutch the way it is for a while (until replacement garage is built !!). However, if I had time I would be trying to get the clutch pedal out of the car and having a good look at the pivot. Cheers, Dave |
| | #15 (permalink) |
| MINI2 Regular Join Date: Oct 2004 Location: Los Angeles Local Time: 04:08 PM
Offline | I have had this exact problem in the "first" clutch of my 03 MCS. At around 26K miles, I started to feel that famous "friction". It only displayed itself after 15-30 mins of driving in heavy traffic. Otherwise, it was just fine (e.g., no problems changing gears, etc). I took it to the dealer at several occasions and got the "cannot reproduce the problem" answer. I took a day off from work and drove the car around for an hour in city traffic, went to the dealer straight, and asked the service adviser to drive it... She felt the same friction and booked the car for a clutch service. After contacting MINI, they replaced the slave cylinder first, master cylinder second, and the whole clutch assembly at the end. It was probably just the bushings... The car has 65K right now. Around 52K, another clutch was put in (with different and more obvious symptoms than the friction). Good luck with your repairs. It may take some "effort" to document it to the dealer, but I would take the time to do it... Clutch problems are messy, since it is a wear-tear item. I know few people that were denied of service by other dealers with the "exact" symptoms that I experienced (and you describe here)... At least, you may want to document your problem in their database in case it fails in the future and you need to make a case. That's what happened for me for when the second clutch failed... The field engineer visited the dealer and diagnosed the car when it was out of warranty, and decided to put in a new clutch since I have been trying to get them acknowledge the problem while the car was still under warranty. Again, good luck! |
| | #16 (permalink) |
| MINI2 Regular Join Date: Nov 2003 Location: Miami Beach Local Time: 06:08 PM
Offline | I have the EXACT same problems as quoted below, 03 MCS. PLEASE any advice on what to do or how to go about lubricating the bushings or changing the slave cylinder myself? Thanks, and |
| | #18 (permalink) |
| MINI2 Regular Join Date: May 2007 Local Time: 11:08 PM
Offline | Sorry, this thread needs a follow up post.... My farting/squeaking clutch pedal turned out to be the cheap plastic clutch release bearing. The stock release bearing is made of plastic and has poor durability. My dealer deemed the problem to be covered under warranty. Also the clutch pressure plate was found to be prematurely worn out. The dealer replaced the whole entire clutch kit assembly under warranty and they gave me an updated OEM flywheel that eliminates the "tick-tick" noise when the car was in neutral. The repair was done 2 months ago and so far the new clutch kit is much better than the original one from factory. The car had 26K miles at the time of the clutch kit replacement and now I am at 29K. The first thing I noticed (Besides no lomger having the annoying clutch fart noise) is that the clutch pedal effort is much lighter than the original clutch but still firm. I would say this has contributed to maximize the driving pleasure of my R53 to new levels ![]() ![]() The car spent 4 days at the dealer because they also did additional maintenance work on it. The clutch kit replacement involves pulling out the engine to gain access to the transmission/clutch area. This is a 9-12 hour job at the very minimum. My dealer did a fantastic job with my car and I could not be more pleased. Make sure your dealer either gives you a MINI loaner or a paid rental car. I was given a 2006 MINI Cooper 5-speed manual to drive that week and I had a hoot in the car. But I was glad to be back in my MCS after all. The farting clutch pedal noise is a symptom of a serious problem with your clutch assembly, specifically, the cluth release bearing. If you ignore it, then you run the risk of getting the clutch pedal stuck to the floor when you least expect it . The noise will not go away by spraying WD-40 under the clutch pedal assembly. The only cure is to get the updated OEM LuK clutch kit and flywheel.I might add that the MINI OEM clutches (In both R53 and R56 generations) are sourced by a German company called LuK. These clutch kits and flywheels are of dubious quality at best and cars and trucks equipped with LuK clutches exhibit very similar problems as we MINI owners have experienced. Let's see for how long my new clutch kit will last. If you intend to keep your MINI past the factory warranty period I highly recommend getting an extended warranty or an extended service contract that covers the clutch assembly components. Unfortunately, it appears that the LuK OEM clutches only last 25K-30K under normal driving conditions. In the future I might look into suitable and better quality aftermarket clutch kit solutions for the MINI. Hope this long post helps. I have the part numbers of the new clutch kit if you are interested. 100% Free of French parts |
| | #19 (permalink) |
Offline | My servicing dealer is Lauderdale MINI in Ft. Lauderdale, FL and my service advisor there is Marc Holstberg. They are absolutely top notch and the best MINI dealer in South Florida. I live in Miami but my MINIs get serviced in Ft. Lauderdale. I also take my MINIs to an independent MINI shop located in the Miami International Airport area called Precision Autowerks. This shop is owned by my good friend and Minis of Miami member, Luis Sanchez. This guy is incredible knowledgeable and he does TOP NOTCH work in your MINI. He owns a track prepared 2005 R53 MCS and has owned 3 MINIs. 100% Free of French parts |
| | #20 (permalink) |
Offline | Finally, this problem is not related to the slave cylinder. However, while the dealer is replacing the clutch kit they should review the part and ensure that it is not leaking fluid. 100% Free of French parts |
