Adam's Polishes
Old May 22nd, 2007, 12:41 AM   #1
jksgoh
jksgoh's Avatar
Local Time: 12:45 PM
HELP car wont START
hi guys,
Drove my car fine this morning for a few mins. An hour later i tried to start it again but it wont start. When i turn the key it makes a loud clicking noise about once a sec while the Headlights flash and if a door is open then that window will jutter down in sync with the headlights .
just a bit of hist, which im not too sure is relevant or not. For past week or so car seems to start up a bit wierd (almost as if its going to stall), but it does start up. i thought that was just due to the cold mornings we are experiencing, as if the engine is already warm it starts up fine. Anyway i also filled up with Vpower racing a week ago too, i usually use mobili or bp, but thought id give it a go as my friend kept raving about it.
Its prob just all coincidence but thought id just put it up in case is not!
Anyway, does anyone know whats wrong with my car???
Australia   Reply With Quote
Old May 22nd, 2007, 12:43 AM   #2 (permalink)
MickyD
Send a message via MSN to MickyD
flat battery?
Australia View MickyD's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 22nd, 2007, 12:52 AM   #3 (permalink)
jksgoh
jksgoh's Avatar
thats what i first thought, but that doesnt seem to fit, cause i was driving just under an hour ago, and no headlights or nething was left on. and if it was a flat bat would it cause the flashing lights and windows going down?
Old May 22nd, 2007, 12:59 AM   #4 (permalink)
Mike Clarke
You are number 6
Local Time: 10:45 AM
Send a message via Skype™ to Mike Clarke
Have you called MINI Assist?
Australia Male View Mike Clarke's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 22nd, 2007, 01:08 AM   #5 (permalink)
minigolf
Blue is the colour!
minigolf's Avatar
Have you tried unplugging it at the wall. It probably just needs a power cycle.
Blat fattery for mine. I know what you're saying re lights and so on, but do you have auto lights or anything like that, car parked under cover??? If all those things are trying to drain power form the battery on start all sorts of odd things could be going on.
How old is the car/battery?
Australia Male View minigolf's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 22nd, 2007, 01:37 AM   #6 (permalink)
im_dave
trust me, I'm a doctor...
im_dave's Avatar
Online
Sounds like the morning start problem could be related to the fuel... I had similar probs with vortex a few weeks back, waited for the tank to run dry before reverting back to BP ultimate... Solved the problem almost instantaneously. I think a few others have also had similar experiences with different fuels:
http://www.mini2.com/forum/australia...ml#post3013234
As for the windows going down and the headlights flashing - probably not related to the fuel, but maybe a flat batt/electronics as aforementioned...
long live the supercharger
Australia Male View im_dave's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 22nd, 2007, 06:31 AM   #7 (permalink)
"Megan"
"Megan"'s Avatar
Quote: Originally Posted by jksgoh (original)
hi guys,
I know bugger all about cars, but do remember having this happen to me once, and it turned out to be related to the alternator? Not even sure if the MINI uses one LMAO!!
Hopefully it is something simple like a fuse that has blown, and nothing nasty. Good luck
Old May 22nd, 2007, 08:25 AM   #8 (permalink)
DaFlake
I miss my MINI
DaFlake's Avatar
Local Time: 10:45 PM
Sounds like a flat battery. The MINI can have just enough power to run stuff but not enough to crank it. Mine did the same thing and it was nothing that a jump couldn't take care of.
Also, the original MINI battery is worthless. I'll be swapping mine out very soon and it is only a year and a half old.
Global Moderator
Old May 22nd, 2007, 09:20 AM   #9 (permalink)
jksgoh
jksgoh's Avatar
hi guys,
thanks for the replies. anyway, i had uni today so wasnt able to do nething about it till the arvo.
Rang up RACV (road side assistance), and basically the battery had died.
Its interesting to note that even though the indicator on the battery was green (ie was ok to go) it still wasnt enough to get my car going. the racv dude said it was cause the indicator would only have shown it to be inadequate when under a load (ie when im trying to start my car). Also he said the lights and the windows was due to the fact that the voltage would have dropped to low causing problems with the electricals.
So ye, just ended up replacing it with a RACV battery, mostly for convenience, and because i really couldnt be bothered waiting till tomorrow to go out to bm and get another battery and i also figured there prob wouldnt be much diff at all. But ye hope it holds up just as well!
Old May 22nd, 2007, 09:32 AM   #10 (permalink)
DaFlake
I miss my MINI
DaFlake's Avatar
It will probably hold up better. As I mentioned, the MINI battery is pretty crap in quality.
Global Moderator
Old May 22nd, 2007, 09:34 AM   #11 (permalink)
jksgoh
jksgoh's Avatar
hi daflake,
just wondering whats actually wrong with the original mini battery to start off with?
cheers
Old May 24th, 2007, 12:02 AM   #12 (permalink)
minisidewalkman
I'm all white now
minisidewalkman's Avatar
Local Time: 03:45 AM
Hi DaFlake,
Just a bit of info for you. The green indicator on the battery only tells you the state of charge in that particular cell, not the other five as well. Also it doesn't show whether the battery is faulty or not. It's not the best diagnostic tool, but just a drivers aid to show the driver the approximate level of charge in the battery.
Wales Male View minisidewalkman's Pepper White & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old May 24th, 2007, 05:05 AM   #13 (permalink)
DaFlake
I miss my MINI
DaFlake's Avatar
Thanks for the info guys and I do know about the little green dot (mine has been black for months).
Anyway, the battery that is in the car is just not the greatest quality and mine didn't last but about a half a year. The first really cold night and the car wouldn't start the next morning. I jumped it and it has been fine since, but I have a feeling that I will be needing another very soon.
When I was younger, I had batteries that would last for years. When the water got low I simply added a bit, jumped if necessary, and we were off and running. My VW Bug battery lasted well over 7 years and it was a DieHard (Sears battery).
Nowadays, I have had to replace the wifes battery twice already (car is 4 years old) and possibly mine very soon (car is almost 2). Seems to me like technology is going backwards on this one.
Global Moderator
Engine wont start Shiggy Faults & Fixes 13 Apr 27th, 2007 05:12 AM
Key wont start the my MCS ScottyBoy Faults & Fixes 1 Jan 11th, 2007 09:16 PM
Car Wont Start, Fuel Gauge on E with 5 gallons texascadillac42 Faults & Fixes 16 May 5th, 2006 02:58 PM
Mini One Wont Start Mikedav MINI One 4 Feb 8th, 2005 10:32 AM
wont start!!! IAN ELLIOTT Faults & Fixes 5 Feb 24th, 2003 06:32 PM
