| Tags: rattle |
| MINI2 Newbie Join Date: Aug 2006 Local Time: 12:44 PM
Offline | Metallic rattle developed Recently i have developed this rattle when my car is idling. Its an 03 MCS. Its coming from the Right hand side. It sounds to be a metal on metal sort of sound. Its only got 66xxx kms on it. I have recently changed the drive belt on it. Not quite sure whether its been there before the drive belt change. Hopefully someone can shed some light on this. thanks |
| Trailer Trash Join Date: Mar 2005 Location: Pipe Creek, Texas Local Time: 09:44 PM
Offline | The early model crankshaft vibration damper can loose integrity between the rubber and hub or outer drive ring. Take tension off the belt and grab the crankshaft pulley, try to rock the pulley, if you can create a “ding”, knock noise, or get it to move any at all, it is bad. Replace with the later model OEM crankshaft vibration damper to solve this issue. My recommendation is to update the early model crankshaft pulley as a preventative measure regardless of whether there is noise or not. |
| Arrrrgggggh......... I 've developed a rattle | T-bone S | MINI Cooper S | 6 | Oct 24th, 2007 07:42 PM |
| I have developed a rattle | Birdog | John Cooper Works & GP | 5 | Jun 3rd, 2007 09:33 PM |
| Metallic Rattle at Rear of MCS | Rand0mRay | 2nd Gen Faults & Fixes | 3 | Mar 30th, 2007 02:19 PM |
| Metallic rattle from underbody? | GTmini | Faults & Fixes | 7 | Nov 7th, 2003 09:49 PM |
| MCS in BMW Steel Blue Metallic or Topaz Blue Metallic | jspranza | MINI Cooper S | 1 | Jul 26th, 2002 11:24 PM |
