FOMSPORT
Tags: , , ,
Old Jul 16th, 2007, 10:15 PM   #1
dave_cooper_s
Loving Mini adventures!
dave_cooper_s's Avatar
Local Time: 12:04 AM
Question Is this hiss normal?
Ok so I have a cooper S with the gtt induction kit. I have had the kit for ages now but it never used to make a sucking/ woosh/ hish type sound like it does now, following the change of the oil breather pipe. It makes this noise when you rev the engine.
I had the common problem of the rocker cover breather/ oil breather pipe becoming soft and sounding like bagpipes, so i got a new one and fitted it today. i noticed the connection into the 'block' at the bottom of the engine through a red plastic seal may not be all that tight. However the hiss is not coming from here, but from the air filter itself.
my question is: is it possible that because the oil breather pipe connection has always been loose, and now the fact that it is tight (at the rocker cover end definately) that this is the reason the woosh has now appeared?
OR is it because it may be loose at the bottom? (it is difficult to tell how air tight the bottom seal it). I am unsure how the filter and this hose are linked in the sense of vacuums etc.
Many thanks for your help in advance!
Dave
Scotland Male View dave_cooper_s's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 18th, 2007, 01:02 PM   #2 (permalink)
dave_cooper_s
bump!
the strange hiss/ door fit problems DrBeast 2nd Gen Faults & Fixes 7 May 1st, 2008 11:56 AM
Engine Hiss? baskers Faults & Fixes 15 Sep 8th, 2006 03:43 AM
Is this normal? ayde_bury MINI One Diesel 17 Nov 28th, 2003 06:18 AM
Is this normal? ScottyG Faults & Fixes 24 Oct 9th, 2003 09:05 PM
Engine Hiss Jorgeaz Faults & Fixes 18 May 13th, 2003 03:58 AM
