Tags: , , , ,
Old Jul 18th, 2007, 09:44 AM   #1
ScottishPedro
Local Time: 11:05 AM
Fitting Spot Lights - Quite Odd
I attached spot lights to my mini over a year ago, but never wired them up. Having browsed various fitting instructions I thought i'd have a go. I used a relay to connect both lights to one port, one to the headlight , one to the headlight attachment screw and one to the positive terminal of the battery. When I tried the main beam (with the bonnet still open) all was well, the lights came on as they should have. However when I shut the bonnet, with the engine off and key in my hand, the spot lights came on..... This is beyond me and I need some advice.
Thanks,
Pedro
Old Jul 18th, 2007, 10:04 AM   #2 (permalink)
Snowie
Snowie's Avatar
Sounds like it could be one of the following or a combination of
Faulty relay - unlikely
Relay is located in such a place that the bonnet liner knocks it when you close the bonnet
Terminals on relay not being insulated so live battery cable terminal touching feed to spot lights - if relay is knocked then this is more than likely the cause
Alan
England Male View Snowie's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 18th, 2007, 10:38 AM   #3 (permalink)
ScottishPedro
Good knowledge Alan. Just swivelled round the relay and hey presto.
Pedro
Old Jul 18th, 2007, 10:43 AM   #4 (permalink)
Snowie
Snowie's Avatar
Pedro
It would be best to ensure that all of the terminals and their connectors are insulated. This way you will avoid any problems in the future and help prevent corrosion and electrical gremlins. Also bets to use a bit of silicon grease or Vaseline on the terminals
Enjoy being able to see better.
Alan
Fitting spot lights choccy20 Exterior 8 Jun 9th, 2008 08:54 PM
Spot lamp fitting help dreadbones Exterior 24 Nov 23rd, 2007 10:11 AM
spot light fitting beninapster Exterior 3 Feb 25th, 2006 07:27 AM
fitting of spot lamps michaelp Maintenance & MINI Care 4 Feb 18th, 2006 11:00 PM
Odd spot in paint jgpmini Maintenance & MINI Care 7 Oct 11th, 2003 02:08 AM
