| Tags: stuck speedometer |
| MINI2 Newbie Join Date: Oct 2006 Local Time: 10:52 PM
Offline | Stuck Speedometer My speedometer is currently stationary @ 30mph. It moves up as i speed up, but when i slow down/the car is stationary it says @ 30mph. Any ideas to sort this problemo out? Cheers! |
| I miss my MINI | It is possible that it is out of calibration. Have you tried resetting the system to see if that solves the problem? You might try it as it seems to reset the system defaults. 1) With the key in the off position press and hold the speedo reset button, turn the key to position one and the screen will say test and a number. 2) Go through the list by pressing the reset button upto test 19 and then wait. 3) The display should then say"log i-off" then "log i-on" over and over again....when "log i- off" appears again press the reset button ....and now you are in the system software. 4) Scroll upto 21.0 Software reset. When reset appears press the button again and you will get a beep and you're speedo needle may vibrate a little (this is normal). 5) Turn ignition off then back on to position 2 for 10 secs then start your car and hey presto its done. Global Moderator ![]() |
| What? Join Date: Dec 2004 Location: Suffolk Local Time: 09:52 PM
Offline | I had that problem with mine (check out the pic, the focus of a lots of stories )My other half pulled apart all the clock and then put it back together again and it was fine. ![]() .......:::::* www.EastCoastMiniClub.co.uk *:::::....... The Original and BEST MINI Club in East Anglia - Essex, Suffolk, Cambridgeshire & Norfolk! ![]() |
| Jumping Speedometer HELP | cloudr | Faults & Fixes | 10 | Feb 1st, 2008 11:54 AM |
| Speedometer does not go to zero | jbz | Faults & Fixes | 0 | Dec 1st, 2006 06:05 AM |
| speedometer gauge? | briguy | Faults & Fixes | 0 | Sep 26th, 2004 05:01 AM |
| Center Speedometer | howardpm | MINI Cooper | 14 | Jun 3rd, 2004 09:35 PM |
| Speedometer Not Accurate? | CT MINI | General Discussion | 10 | Feb 3rd, 2003 10:09 PM |
