| Tags: blow up, cooper, engine, oil, trouble |
| It's just a car... right? | Appeal to those Mechanically Minded Mini2'ers - Blown engine! So here's the story: I have a 2004 MC ( http://www.mini2.com/forum/general-d...tml#post731069 ) a couple of weeks ago, on the way back from work, it started making a faint whirring from the engine. I drove from work straight to my dealer (no more than 15 miles) The car had done 55,000 miles or so and is in top condition. By the time I arrived, it sounded like there was a giant woodpecker in the engine bay. The Tech listened for about 5 seconds, told me the engine was finished (later established due to NO oil ) and I would need a new one! When I asked for the cost, I was told.. wait for it...£7,500 for a new one or £5,500 for a reconditioned one!I had just ordered my new MCS (due end of this month costing just shy of £25k!! from the same dealer!) and amazingly they offered me £3k for trade in!!!! I deemed this unacceptable and promptly went about locating a different method of getting the Old MC back on the road. The best I could come up with was £485 for a back end write off 04 Cooper engine with 11,000 miles on the clock from a breaker. However even a local mechanic I know quoted £2k for the labour! I drive the car hard on occasion, but never beyond its limit. I had just spent nearly £1,500 on new tyres, brake pads, discs and a new exhaust as well! I am aware that my reliance on the cars early warning system has been my error here (I expected an oil light if I was running low!) The car was/is fully TLC serviced My questions to the Mini2 community are as follows: Has anyone had this or similar happen, if so what was your resolve? Can I replace just the damaged parts? Should the light have come on? if so, do I have a case against Mini? Is the dealer being ridiculous on price? Exp. having just ordered a rather costly MCS Any response/pointers would be appreciated. Last edited by R56_JCW : Sep 4th, 2007 at 10:43 PM. |
| MINI2 Sponsor Join Date: Mar 2006 Local Time: 10:27 PM
Offline | This has happened before,we have had a couple of engines damaged through lack of oil,the main bearings and con rod bearingswill have gone, the crank shaft may also be damaged,the first engine we had ,we tried new bearings at the customers request ,but it did not last more than a week due crank wear/damage. The light for low oil pressure does light up when very low on oil,but if at speed the damage is done by the time it illuminates A couple of times I have posted on the importance of checking oil level,and highlighted the fact that if you go off the dipstick ,the engine will sieze (it cannot pick up oil from the sump as the level is below the pick up inlet.in the sump) Your dealer will not be interested in any responsibility your hand book tells you to check your oil weekly I believe. That is what main dealers charge,the diesel engine is even more!! and harder to find second hand I have a cooper engine here if it is of help ,fitting charges vary around the country but no one is going to work all day replacing the engine for a couple of quid,where are you located? |
| | #6 (permalink) |
| Clubman Convert Join Date: Jan 2004 Location: Hampshire Local Time: 10:27 PM
Offline | The dipstick is still the best method to check your engine oil level. I check mine religiously on a weekly basis, and again before any long trips. MiniMania was saying that if the level drops off the bottom of the dipstick you're in the mire ![]() ![]() |
| | #7 (permalink) |
| MINI2 Regular Join Date: May 2004 Location: Wirral / Leeds Local Time: 10:27 PM
Offline | Just thinking about the oil level, when I questioned a BMW service person about a problem, and whether it was due to a low oil level, she said "the oil light would be on if it was too low" and now we are saying that this might not be the case. |
| | #8 (permalink) |
Offline | The oil light is based on oil pressure, and when it illuminates its often too late as the engine has probably been running low for some time. There is no substitute for regular level checks via the dipstick, as recommended in your manual. ![]() |
| | #10 (permalink) |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 10:27 PM
Offline | This is why you do weekly checks ![]() Most of the warning lights on a car are on/off not progressive and usually by the time the light up the damage is done. If your oil light comes on in a car then your engine will have already suffered damage....same as the engine water temp guage in the MINI (it goes from middle line, to hot in about 2 seconds!) Good luck and sorry to hear about this but I think its gonna be a bite the bullet thing and new engine or get a rebuild from somewhere like Lohen, GTT, MINImania but either way it will be ££££ to fit, buy or rebuild ![]() |
| | #14 (permalink) |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 10:27 PM
Offline | I think /presume £7500 is fitted & including vat? but that is very expensive all the same. You should check oil level every week, theres no 'please add one litre light'. 1 in 3 cars that comes in to us for GTT conversions needs oil..anything from half a litre to 2.5 litres ![]() Best Regards Roland GTT ![]() |
| | #16 (permalink) |
Offline | Hi, yes we can strip it down & check for damage, as long as the bores & pistons are ok then it may be just a case of regrinding the crank main and big end journals and rebuilding with undersize bearings. This is a proper fix that should be as good as new. If the engine was burning oil in the first place (which resulted in loss of oil pressure) then a new set of piston rings would be advisable even if not going for pistons/rebore etcBest Regards Roland GTT ![]() |
| | #17 (permalink) |
| Mini2 Sponsor & Tuner Join Date: Jun 2005 Local Time: 02:27 PM
Offline | if you are going to tear it apart, do it right by boring it and fitting quality pistons. Make sure you change the oil pump too ! You can get a fully rebuilt , bored and balanced engine with ARP fastners and cp forged pistons and a CNC'd big valve head for $5,000 US |
| | #18 (permalink) |
| MINI2 Master Join Date: Jul 2005 Location: Beds Cambs Northants Local Time: 10:27 PM
Offline | I think he just want it back on the road asap as he has a new S ordered. Give us a bell and we can fit the engine for you cheaper than what you've been quoted. Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 IT'S NOT HOW MUCH YOU SPEND BUT HOW WELL YOU SPEND IT |
| Blown Engine : -( | danny b | Faults & Fixes | 5 | Oct 20th, 2006 07:09 PM |
| Blown Engine / Puddle | coopmush | Faults & Fixes | 21 | Sep 1st, 2006 02:20 PM |
| Help Please!!! Blown Engine?!?! | oo7dw | Faults & Fixes | 9 | Jun 3rd, 2006 10:57 AM |
| Cooper Blown Engine | lazza | Engine & Drivetrain Tuning | 6 | Apr 12th, 2005 07:29 PM |
| Blown engine after tuning, anyone? | cordial | Engine & Drivetrain Tuning | 7 | Jul 28th, 2003 05:23 AM |
