Performance Torque
Tags: , ,
Old Sep 11th, 2007, 08:20 PM   #1
hanoi
hanoi's Avatar
Local Time: 11:56 PM
Handbrake gaitor trim is broken R50
Long time lurker, first time poster.
I noticed that the handbrake gaitor on my 2002/ONE was loose at the bottom and when I checked it, the plastic oval seating was broken into 2 U shaped pieces. They have now become unglued from the gaitor itself.
Can anyone advise which bits do I need to buy and is it easy to repair, or should I give in and pay BMW the usual small fortune to fix it for me?
Thanks in advance.
View hanoi's Pure Silver & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Sep 11th, 2007, 10:48 PM   #2 (permalink)
oldnell
Hi there
To clarify, I think you're talking about the plastic piece that the leather of the gaiter attaches to, but which is invisible when fully assembled.
It isn't possible to buy only this part from Mini dealers' parts departments. They only do the entire gaiter at around £30 or so. I didn't bother.
However, if you hunt around (maybe put a "wanted" in) you can probably find a plastic gaiter for sale from someone who's fitted a leather one.
I've also broken mine, but it's not badly broken so I'm living with it.
Oli
View oldnell's Solid Black & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Sep 12th, 2007, 01:37 PM   #3 (permalink)
hanoi
hanoi's Avatar
Yes thats the bit. It has the tabs on it which hold the gaiter in place. Mine wasn't bad for a while but now its in halves.
If I spend the £30 on the gaiter is it hard to fit?
Old Sep 12th, 2007, 05:10 PM   #4 (permalink)
richg40
No, it's not hard to fit.
Old Sep 13th, 2007, 08:15 PM   #5 (permalink)
oldnell
Agreed, it shouldn't be hard at all. I'd probably take the approach of removing your old broken plastic rim (to get an idea of how fiddly that is) and then swapping just that part into your existing gaiter. Otherwise you'll have to remove the knob. See richg's post below for how to do it.
Oli
Last edited by oldnell : Sep 14th, 2007 at 10:10 PM. Reason: Got rid of bad advice!
Old Sep 13th, 2007, 10:10 PM   #6 (permalink)
richg40
Dont pull the handle up very hard as this will break it. instead pull the cap off the end, by the button. there'll be a little tab underneath this. lift the tab (carefully or it will snap off)and the handle will slide off complete with the gator.
Old Sep 14th, 2007, 10:10 PM   #7 (permalink)
oldnell
Thanks for the correction, richg40!
Old Sep 15th, 2007, 10:35 AM   #8 (permalink)
mikeythemini
I can't get no sleep
mikeythemini's Avatar
You could replace it with an alcantara hand brake boot - comes with new plastic 'ring' & looks lovely - £24.95 inc vat - NewMINIStuff.com
You could also get a matching alcantara gear boot - £19.98 inc vat NewMINIStuff.com
Old Sep 17th, 2007, 10:15 AM   #9 (permalink)
hanoi
hanoi's Avatar
Does this look and feel like suede?
Old Sep 17th, 2007, 11:34 AM   #10 (permalink)
mikeythemini
Yes
Old Sep 17th, 2007, 09:01 PM   #11 (permalink)
oldnell
This is a timely thread. I just broke my gaiter while putting on my chrome one. Whoops!
It really would be useful to find a source of the plastic bit only. Oh well!
Oli
Old Sep 19th, 2007, 04:34 PM   #12 (permalink)
hanoi
hanoi's Avatar
Done it.
Bought a BMW spare "M34.42.1.171 Boot" for £23.66 plus VAT = £27.80.
Old gaiter and handle slid off as described above, did need a little persuasion.
Dilemma; the old gaiter with the broken seat was fixed to the brake handle with a fixed plastic tie and I couldn't just swop over the new seat to the old gaiter as the new gaiter was glued & welded to the plastic seat (the bit which had broken).
So I cut the tie off. New gaiter then fixed to the handle with a piece of fuse wire, twisted at the join. Slid handle back on & popped the plastic seat back into place quite easily. The tab at the front needs to be put in place first, then the two vertical tabs at the rear, The others just pop into place.
Very simple. I hope the laboured detail helps someone else.
Thanks for the help and advice.
chrome handbrake trim any5at32 Interior & Ice 0 Aug 26th, 2007 01:15 PM
Gear & Handbrake Gaitor venox22 Interior & Ice 7 Apr 24th, 2006 11:00 AM
Best way to reattatch handbrake leather trim/gator ? DCM Interior & Ice 3 Aug 28th, 2004 10:53 AM
Handbrake Gaitor Darren Metcalfe Interior & Ice 11 Jun 9th, 2004 06:36 AM
Handbrake Gaitor-Refitting-Pls help!!! ALD0 Faults & Fixes 2 Jun 7th, 2004 10:20 PM
