| Tags: coolant, headgasket |
| | #21 |
| MINI2 Regular Join Date: Jan 2007 Location: Eastern USA Local Time: 07:02 PM
Offline | I should have mentioned for emphasis, any time you have your cooling system opened, you should verify the system is bled properly before driving the car by quizzing the tech that worked on it about the procedure he used, it may save your engine. I would never let just anyone touch this cooling system, it is THAT touchy. |
| | #22 (permalink) |
| MINI2 Newbie Join Date: Oct 2003 Location: Alexandria,Virginia Local Time: 11:02 PM
Offline | Coolant Change I,ve just done a coolant change on the Cooper S, and was surprised how little coolant was required to fill it again. I had removed the bottom hose but thought that because the exit pipe from the radiator pointed upwards, that it was not allowing all of the coolant in the lower radiator to drain. Later I noticed that there were two small bolts holding the plastic lower radiator pipe to the radiator. Has anyone tried undoing these and letting the colant drain from there? |
| | #23 (permalink) |
| MINI2 Master | Oldmots, so when I was told after having my radiator replaced by Cotswold BMW in Cheltenham that the coolant level dropping by more than an expansion tank's worth as airlocks work their way out the system is perfectly normal, was I being misled at the possible expense of the longievity of my engine? |
| MINI Emergency services | *Vikki* | General Discussion | 33 | Mar 29th, 2007 11:53 AM |
| Mini Emergency- --- Thank You | simeds | General Discussion | 7 | May 9th, 2006 09:33 PM |
| Mini Emergency services | Kboy | General Discussion | 8 | Feb 10th, 2004 09:24 PM |
| MINI Emergency Service | Wychall | General Discussion | 11 | Dec 29th, 2003 01:29 AM |
| MINI Emergency | D/SCooperS | General Discussion | 11 | Oct 29th, 2003 06:52 PM |
