Adam's Polishes
Tags: ,
Old Sep 21st, 2007, 04:57 PM   #1
JAMIE1131
JAMIE1131's Avatar
Local Time: 11:01 AM
MINI Emergency!
It looks like I'm about to find out how good MINI emergency service is! Started up the car and heard the sound of bubbling water from the dash, checked the coolant and its spat most of it out and is now well below the minimum level. It had an inspection 2 and coolant change less than 500 miles ago and I complained then about the fan coming on a lot to be told its normal!!!
United Kingdom Male View JAMIE1131's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 21st, 2007, 05:04 PM   #2 (permalink)
Wurzel
Oh arr
Sounds like your inspection 2 was not done properly, The mini emergency service are usually a lot more honest than the people behind the desk at the dealers, make sure you tell him/her that the fan kept coming on since the inspection.
if you can get the mini E/S to say the inspecton is at fault this will save you lots of moaning to the dealer.
Good luck.
United Kingdom View Wurzel's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 21st, 2007, 08:25 PM   #3 (permalink)
richg40
The bubbling behind the dash is air trapped in the heater matrix. this is a common fault. it needs rebleeding, as it sounds like it wasnt done properly the first time.
Old Sep 22nd, 2007, 05:11 PM   #4 (permalink)
Gristy
Ruby, Ruby, Ruby, Ruby...
Gristy's Avatar
Was the inspection 2 done at Sytners?
England Male View Gristy's Chili Red & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Sep 22nd, 2007, 05:14 PM   #5 (permalink)
JAMIE1131
JAMIE1131's Avatar
yep! they now have the car back!
Old Sep 22nd, 2007, 07:11 PM   #6 (permalink)
Jaw_F430
Jaw_F430's Avatar
I had a similar problem with the fan coming on a lot and coolant level keep going down. Took it to the dealer and said the thermostat housing was cracked. Replaced under warranty, ok now
United Kingdom Male View Jaw_F430's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 22nd, 2007, 07:13 PM   #7 (permalink)
MINICooperMurph
aka Nick
MINICooperMurph's Avatar
Send a message via AIM to MINICooperMurph Send a message via MSN to MINICooperMurph
my fan seems to come on with the air con. Is that normal?
United Kingdom Male View MINICooperMurph's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Sep 23rd, 2007, 12:04 PM   #8 (permalink)
richg40
yes
Old Sep 23rd, 2007, 05:34 PM   #9 (permalink)
Gristy
Gristy's Avatar
Not been back there since i bought my MINI - i go down to Wollastons now
Old Sep 24th, 2007, 04:44 PM   #10 (permalink)
JAMIE1131
JAMIE1131's Avatar
Sytners called today and confirmed what I had feared, Head gasket failure!!!! how can this happen on a car with 65000 miles, less than fours years old and a full service history?
being a powertrain design engineer I drive it with sympathy, fill up with top quality fuel and have it looked at whenever it makes the slightest noise. The warranty runs out in December and I'm fed up of defending it now and I'm tempted to get rid when I get it back.
Old Sep 25th, 2007, 12:21 PM   #11 (permalink)
LoDRpR
LoDRpR's Avatar
Local Time: 01:01 PM
I have the same issue in the last 2 weeks, the fan keeps starting again and again(with A/C turned off). The temp indicator inside the car shows everything is normal.
can somebody tell me what might be wrong? (I don't have any service to trust 100% so I want to know first a list with possible fauls before asking them)
thanks!
Romania Male View LoDRpR's Indi Blue & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Sep 25th, 2007, 05:58 PM   #12 (permalink)
JAMIE1131
JAMIE1131's Avatar
Car is now at home with new head gasket. going back in on Friday for replacement of a busted HT lead and to replace a bolt from the intercooler mount.
I'm expecting a call from Sytner tomorrow to discuss a replacement vehicle, watch this space!
Old Oct 1st, 2007, 07:33 PM   #13 (permalink)
Gristy
Gristy's Avatar
What did you get out of our Sytner friends?
Old Oct 2nd, 2007, 11:22 AM   #14 (permalink)
Ant FR
sound like al ot of you guys need a scanguage. Your fan on the MCS should cut in at 104c and will lower the temp straight back to 92-93 which is what the MCS sits at as a running temp. i do prefer the scanguage to monitor this. believe me, do not trust the vehicle temp guage as it is very inaccurate.
Old Oct 2nd, 2007, 12:05 PM   #15 (permalink)
JAMIE1131
JAMIE1131's Avatar
Sytner are being excellent about it actually. They have agreed a replacement vehicle and are looking for an appropriate car, trouble is mine is quite highly specced so its quite hard to find another one like it.
Old Oct 2nd, 2007, 10:24 PM   #16 (permalink)
Gristy
Gristy's Avatar
Sounds like they are doing a good job in sorting you out then - good luck with finding a new one
Old Oct 7th, 2007, 02:29 PM   #17 (permalink)
JAMIE1131
JAMIE1131's Avatar
Old Oct 7th, 2007, 10:01 PM   #18 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
very odd.....Now did the head gasket fail because it was its time or because the engine overheated?
Old Oct 8th, 2007, 05:12 AM   #19 (permalink)
JAMIE1131
JAMIE1131's Avatar
I think one possibility is an airlock in the coolant. This failure happened les than five hundred miles after having the coolant changed. The temp gauge didn't leave the middle. Oil looked okay afterwards but there was a hell load of steam from the exhaust whilst it was being loaded onto the recovery truck!
Old Oct 8th, 2007, 06:55 PM   #20 (permalink)
oldmots
Local Time: 06:01 AM
You may be right about the airlock. An airlock will create a bubble of air that allows the metal touched by the air bubble to superheat and warps the metal. These cars are easily airlocked and require extensive bleeding when changing coolant, more so than most cars. There are three bleed valves and the heater must be opened electrically and held open during refill. In addition, the pressur cap must be kept open while the newly refilled system is run up to the point the thermostat opens and then watched until all bubbles stop coming up in the filler neck or header tank in the S.
MINI Emergency services *Vikki* General Discussion 33 Mar 29th, 2007 11:53 AM
Mini Emergency- --- Thank You simeds General Discussion 7 May 9th, 2006 09:33 PM
Mini Emergency services Kboy General Discussion 8 Feb 10th, 2004 09:24 PM
MINI Emergency Service Wychall General Discussion 11 Dec 29th, 2003 01:29 AM
MINI Emergency D/SCooperS General Discussion 11 Oct 29th, 2003 06:52 PM
