| Tags: light, reverse |
| MINI2 Newbie Join Date: Mar 2007 Location: Brum-a-jum Local Time: 02:27 AM
Offline | No Reverse Light?!?! How do all! Need a little help if you can. I've got a 2001 coop, and when I put it into reverse the reverse light doesn't come on. Now, I've change the bulb several time and even tested the bulb's in the rear cluster of my van to check that there ok. They all work fine!! Is there a problem with the wiring or reverse switch on the gear box that i should be investigating. Or is there a quick fix for this!! Open to all suggestions!!! ![]() |
| MINI2 Newbie Join Date: Aug 2006 Location: West Yorkshire Local Time: 02:27 AM
Offline | The reverse light switch will have failed on the gearbox. It happened with my previous mini one. Iv just got a 1st gen cooper and it has the same problem. The switch is only around £5. You need to remove the air filter housing to access the switch which is at the top of the gearbox. The mechanic I used charged me £15. |
Offline | Cheers peeps, at least i know where the bloody thing is now!!!! Will be having a look at it tomorrow, so will update when i've finished breaking, er...... i mean fixing it!!! ![]() |
| Reverse light and brake light | Lorenzo7 | General Discussion | 0 | Sep 30th, 2007 06:08 PM |
| Reverse light switch - Help!! | Cally95 | Faults & Fixes | 9 | May 7th, 2007 06:07 PM |
| reverse light | SeXiTuPJoEy | Faults & Fixes | 0 | Sep 19th, 2005 06:56 PM |
| White stobe light where reverse light used to be? | CYNMINI | Exterior | 8 | Sep 28th, 2004 10:42 AM |
| Reverse light is not working.. | leon1982 | Faults & Fixes | 3 | Jun 18th, 2004 10:30 PM |
