Adam's Polishes
Tags: , ,
Old Oct 5th, 2007, 07:42 PM   #1
Poppyslops
Local Time: 01:21 PM
United-Kingdom Exhaust deterioration - Cooper S
Hi
I have just purchased a 53 plate Cooper S from a dealer. The MOT has an advisory sheet which states that, 'the offside rear exhaust system is partly deteriorated'
The car has done 19k miles and the dealer neglected to tell me about it.
I have spoken to 2 separate Mini dealers about the costs for replacement and both of them immediately knew what the problem was and advised that whilst this appears on MOTS quite a bit, the exhaust has several skins and it only appears to be the outer one that shows early wear.
This has given me some confidence as I didn't give them a leading question. Does anyone out there has similar experience or knowledge? Basically, should I be concerned or not? A replacement seems to be about £300 for the back box.
Many thanks, Andrea
Old Oct 5th, 2007, 07:56 PM   #2 (permalink)
ScottyBoy
Obsessive Car Cleaner OCC
ScottyBoy's Avatar
The exhaust does have a few skins as mentioned but personaly id keep on there back to have it replaced.
Other wise look on ebay they go cheap enough on there.
Scott
Old Oct 6th, 2007, 09:06 PM   #3 (permalink)
oldnell
I wouldn't have expected a dealer to draw your attention to it. It's on the MOT, which you should have checked when you bought it.
What I'd be most concerned about are the mounting brackets. If they're the type that clamp around the exhaust boxes, check that the mountings aren't rusting through on the top corners. That seems quite common and it's worth catching before the box drops off.
They do have several skins. As long as the mounting is good, you can let keep an eye on it and only replace it when you really need to.
It's worth a go asking the dealer to fix it, but personally I don't think there's much you can do if they don't agree. They might give you a discount on a new exhaust, though.
Oli
View oldnell's Solid Black & Body Color 1st Gen MINI One Profile   Reply With Quote
Deterioration in ride quality of a One a-z Faults & Fixes 4 Dec 1st, 2006 01:46 PM
John Cooper Works Exhaust Trim to stock Cooper S billy_wizz_69 Engine & Drivetrain Tuning 2 Aug 23rd, 2005 06:30 PM
SOLD: Magnex 3.5" Cooper stainless exhaust ONE/Cooper with pics! StevePSB For Sale 15 Aug 5th, 2005 03:35 PM
**UK** Magnaflow Cooper S exhaust swap for other aftermarket s exhaust B4d4Bing For Sale 3 Apr 11th, 2004 05:51 AM
Rapid deterioration of leather seats? adamlondon Interior & Ice 4 Jan 7th, 2004 03:04 AM
