Tags: , ,
Old Oct 24th, 2007, 07:40 PM   #1
KillerByte
Custom User Title?
KillerByte's Avatar
Local Time: 03:42 AM
Send a message via MSN to KillerByte
Engine stalling when cold
My 2002 MINI Cooper started playing up this morning. I got in and started the engine while I was putting some stuff in the glovebox, then set off to work. No more than 200 yards down the road is a T-junction which I pulled to a stop at. As the car came to a halt it studdered and stalled. I started the engine again and set off. It still felt a bit shaky initially but as the engine warmed up things returned to normal.
This evening, I got into the car and again started the engine as I was putting stuff in the glovebox. I drove to the end of the road and then downhill towards another T-junction. I pressed the brake pedal and then as the car approached the junction I put the clutch in, and the car came to a halt and then cut out. No shudder, no jolt, it just cut out. Again I started the engine up and resumed my journey and the car seemed fine.
It was about 6ºC this morning and 10ºC this evening. The car has been fine in temperatures much lower than this in the past. At last check the oil level was fine, and I can't check it tonight as it's too dark but I will check tomorrow morning. I should also note that no dashboard lights came on prior to the engine stalling.
Any ideas why my MINI might be misbehaving from cold?
England Male View KillerByte's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 24th, 2007, 07:45 PM   #2 (permalink)
supa-dupa-cooper
In S Club Heaven!!
supa-dupa-cooper's Avatar
Maybe shes coming out in sympathy for Bow's buzzing speedo
Hopes shes ok
United Kingdom Female View supa-dupa-cooper's Chili Red & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Oct 24th, 2007, 08:21 PM   #3 (permalink)
iain cooper
bad petrol? condensation on electrics ?
Old Oct 24th, 2007, 08:24 PM   #4 (permalink)
KillerByte
Custom User Title?
KillerByte's Avatar
I'm a third of the way into this tank of fuel. It's Shell V-Power from the garage I usually fill up at.
Not sure about the electrics.
Old Oct 25th, 2007, 08:58 PM   #5 (permalink)
Peartreeproductions
Mini spanker
Peartreeproductions's Avatar
DIY
My Cooper for the last 2 or 3 (cant remember) winters has juddered in very cold weather, and very occassionaly stalled, less than 5c, and got very close to stalling at T-junctions and traffic lights.
The mini dealer failed to diagnose it twice always taking so long to book it in that the weather was far warmer by then. Anyways this summer I replaced the air filter with a K&N filter and the old original filter was horrendously filthy. This year there have been several mornings when the weather has been less than 5c and it hasnt juddered at all, perfectly smooth. So, touch wood, I was wondering if it might have been the air filter not performing so well in very cold weather.
I now have 43,000 miles on my MC and recently had a service however they don't touch the air filter at that time. It may be that replacing your air filter might be worth a shot. K&N etc. are only about £25ish.
Hope this helps.
United Kingdom View Peartreeproductions's Pure Silver & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 25th, 2007, 09:56 PM   #6 (permalink)
KillerByte
Custom User Title?
KillerByte's Avatar
Ah, that's a good idea.
I'll check it this weekend. Thanks.
Old Oct 26th, 2007, 12:19 PM   #7 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Id say just check all the connections like plugs especially..... reminds me of my problem I had a couple of months ago with vanished again before I found the root cause.
Old Nov 1st, 2007, 09:55 AM   #8 (permalink)
KillerByte
Custom User Title?
KillerByte's Avatar
It did it again this morning and it wasn't particularly cold (12ºC).
Want to get a local garage to look at it as I don't want to pay dealer rates.
Old Nov 3rd, 2007, 01:09 PM   #9 (permalink)
MINI-Morgan
MINI Obsessed...
Old Nov 3rd, 2007, 05:43 PM   #10 (permalink)
wincakes
LOONEY!!
wincakes's Avatar
Send a message via MSN to wincakes
Hmmmmmm. your not having much luck ATM, are you Kev?? Hope you get this sorted soon!
ALTHOUGH SHE NEEDS A BIT OF GUIDANCE, LESLEY WILL BE MY BIATCH FOR NOW...!
United Kingdom Visit my Blog at the Motorcade Female View wincakes's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 5th, 2007, 04:33 PM   #11 (permalink)
KillerByte
Custom User Title?
KillerByte's Avatar
The car's staying with the dealer overnight. They haven't managed to find the cause of the problem but did find that the rocker cover gasket is leaking, one of the sidelight bulbs needs replacing and one of the wiper blades also needs replacing. They'll have another look at it tomorrow morning now after it has sat overnight in the cold.
So now currently car-less waiting for someone from work to give me a lift home.
Old Nov 5th, 2007, 10:07 PM   #12 (permalink)
oldmots
Local Time: 10:42 PM
Stalling has a number of causes: low fuel pressure (pump, filter, fuel pressure regulator, fuel pump relay), low battery capacity, throttle body idle motor failure, ECU software glitch. From the sound of it, I would get the battery load tested and themn get the ECU reflashed to catch glitches. The EPROM memory in these ECUs seem to be more vulnerable to voltage fluctuations than some cars.
Old Nov 5th, 2007, 10:15 PM   #13 (permalink)
REDHOT CHILLI COOPER
REDHOT CHILLI COOPER's Avatar
How many miles have you done? Had any problems starting in the damp/cold?
I'd go for simple first - Spark plugs and air filter.
Replaced mine last year after 25,000 miles. The filter was black and the plugs were twice the gap they should be. Don't know how these dealers get away with the service intervals recommended.
After changing the above I also got an extra 50 miles out of a tank!!
England   Reply With Quote
Old Nov 19th, 2007, 11:37 AM   #14 (permalink)
KillerByte
Custom User Title?
KillerByte's Avatar
Update: My car was looked at by Sytner Nottingham two weeks ago for this issue. While it was in, they could not get the car to repeat the fault I was describing and said they could not find anything which would cause the issue. The diagnostics computer picked up no faults either. While it was in they did find some other things - an oil leak for which they replaced the rocker cover gasket and cylinder gasket and some other non-engine bits and pieces. I was quite shocked about the oil leak as I've never noticed oil under the car and as far as I was concerned the oil level hadn't dropped. This was quite expensive as you can imagine from the labour costs the dealer charges.
After getting the car back, it seemed fine for a couple of days and then it started playing up again last week. This morning it stalled twice on the way to work. The sequence of events was as follows:
  1. Start the engine and let run for a moment (idling at 1,200 rpm)
  2. Select 1st gear and pull away towards the end of my road
  3. Slow down for junction and put clutch in
  4. As soon as the clutch was in, the revs dropped to 300-400 rpm and the car cut out
It did this again for the next junction I stopped at and nearly did it as I waited to turn right on a hill. It's not like I'm not using the car often enough - I did 200 miles over the weekend.
Due to the age of the car, I have taken out a new warranty through a third-party company so I shouldn't have to pay too much this time around. I'm just fed up of people behind me wondering why I keep stalling my car!
Old Nov 19th, 2007, 04:19 PM   #15 (permalink)
supa-dupa-cooper
In S Club Heaven!!
My car wouldnt start on thursday night It just kept turning over, then sounded a bit rough when it did start
I wouldnt have minded but I was parked somewhere I shouldnt have been, ie. in the middle of a cement works with 3 other MINIs
Old Nov 19th, 2007, 05:49 PM   #16 (permalink)
Vitesse
Some of the diagnostics point towards a problem I had last year, which was battery related.
In the morning I have to drive mine out of the garage and then go back in and make sure the house is locked up and alarm is on etc.... Which means switch the car on and then off again in a short period of time. On a really cold morning last year it started fine, drove it out switched off.
It started fine but as soon as I went to move it but sort of died to really low revs and even with extra throttle it just wouldn't rev any higher, then suddenly leapt back into life again. It was almost like fuel starvation. Couple of times over the next few days it did the same sort of thing.
Took it to the dealers and they checked it out but couldn't find anything wrong. But virtually insisted they needed to keep it and charge me lots of money to inspect it further!!!!
Took it to Halfords and they checked the battery out and it was not fully charged. I do quite short journeys mostly and the battery simply didn't get enough charge into it. Gave it a decent charge over night and it was fine the next morning.
I have a trickle charger that I plug in overnight, on really cold nights. It just put a really low charge into the battery and keeps it nice and healthly.
I'm on the same battery 12 months later, so it could be simply a case of your battery on it's way out?
Old Nov 20th, 2007, 04:49 PM   #17 (permalink)
KillerByte
Custom User Title?
KillerByte's Avatar
Sytner Nottingham have had the car today. In fact they still have it! They still cannot repeat the fault I'm describing and the computer isn't bringing any faults or errors up. I asked them what else they've checked and when they went sheepish on me, it's clear they haven't checked anything else like the plugs, battery, fuel lines, electrics etc. They're going to see if it does it tomorrow morning but I'm losing a lot of faith in the dealership right now.
Admittedly the car didn't play up last night, or this morning for that matter. However, the problem is clearly intermittent and there has to be a root cause.
So that's two out of two visits where the car has had to be kept overnight and I don't have a car. Fortunately the company I work for has allowed me to take a pool car (MINI ONE) home so I'm not completely vehicleless. Last time I had to make my way home and to work the following day using public transport.
Old Nov 20th, 2007, 04:57 PM   #18 (permalink)
Vitesse
From what I can work out they can plug it in to the diagnositics computer and look for fault codes. But it's not able to check whether the battery is ok or not, which is quite sad for a fairly high spec bit of kit!
Old Nov 20th, 2007, 06:16 PM   #19 (permalink)
faudisport
Local Time: 02:42 AM
[hi Have The Engine Management Temp Sensor Tested With An Ossilloscope If It Stays Within The Specs Its Possible The Ecu Thinks The Engine Is Warm When It Is Not & It Wont Flag A Fault Code Even Though It Is Faulty
Hope This Helps
Old Nov 21st, 2007, 12:27 PM   #20 (permalink)
KillerByte
Custom User Title?
KillerByte's Avatar
Sytner Nottingham have just phoned. My car didn't play up for them this morning when they tested it. They say they've reset one of the control units on the car back to factory default settings which may resolve the issue and now the service advisor is having the technicians do a final check on the car before I have it back later on.
Cold Weather Stalling FrenchCori Faults & Fixes 7 Feb 14th, 2006 08:55 PM
Stalling problems docmagoo2 Engine & Drivetrain Tuning 1 Sep 29th, 2005 07:37 PM
