Old Nov 6th, 2007, 09:39 PM   #1
Ruskins JCW
Ruskins JCW
Local Time: 01:16 AM
Engine Cut Out
Hi Guys
Had something very worrying happen on Monday morning driving to work.
I was chaging gear from 4th to 5th and the car completed died and through up the engine management yellow light and traction control light. For ten minutes the car hardly pulled and in any gear and sounded like a tractor with no supercharger to be heard. After 10 mins driving it all came back again but with the warning lights still present.
I had the mini customer service team come out to me and look at my car at work (arrived in 45 mins only good service i had ever had with BMW so far)
He plug in the computer to read the fault codes. All was displayed that it misfired on a cyclinder.
He asked me to take the car for a spin and all seemed ok so there was nothing more he could do.
Should i be worried by this??
And driving home today whenever i press the clutch i get this rubbing/deep squeeking noise from the engine bay going to book it into the garage again (5th time in 2 months if you count the call out). Any ideas what might be causing this???
As if the car hasnt had enough work with just about every oil seal being replaced as well as sump gasket and rocker cover. Car has only covered 16k
Thanks for your help
United Kingdom Male View Ruskins JCW's Hyper Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 6th, 2007, 09:55 PM   #2 (permalink)
1320autos
1320autos's Avatar
There was a similar case a couple of months ago and it was the coil pack which was the problem.
IT'S NOT HOW MUCH YOU SPEND BUT HOW WELL YOU SPEND IT
Old Nov 6th, 2007, 10:00 PM   #3 (permalink)
Ruskins JCW
Ruskins JCW
engine
What is the coil pack?? Is this to do with the missfire or the clutch pedal?
Oh and warrenty runs out in feb so want the car in tip top shape before GRS and Manifold added.
Thanks for your help bud will be coming to your place in feb as you are very local
Old Nov 6th, 2007, 10:10 PM   #4 (permalink)
1320autos
1320autos's Avatar
Misfire, its on top off the rocker cover and has the 4 spark plug leads attached to it.
Which ex manifold have you got??
Old Nov 6th, 2007, 10:14 PM   #5 (permalink)
Ruskins JCW
Ruskins JCW
engine
Just the standard one
Warrenty runs out in feb so will be looking to change IC and manifold then. I know you guys supply and fit GRS IC's do you also supply manifolds?
Thanks for the info on the coil pack, any ideas with the clutch issues?
Scary Moment-engine/lights cut out minibbb Faults & Fixes 2 Dec 30th, 2005 08:45 PM
Mini Cooper S Engine Cut Away Photo??? MINImotor MINI Cooper S 5 Nov 30th, 2004 12:16 PM
Getting cut off... alopukhin MINI Cooper S 14 Nov 4th, 2004 02:02 PM
Engine fan cut-off lusomini MINI Cooper S 6 Sep 26th, 2003 12:34 PM
