Mighty Stripes
Tags: , ,
Old Dec 6th, 2007, 04:41 PM   #1
westycoopers
CHEQUE IT OUT
westycoopers's Avatar
Local Time: 11:18 PM
United-Kingdom tyre pressure light
i have an 04 cooper s with aftermarket 18" wheels and my tyre pressure light comes on all the time and when i stop to check the tyres they are all ok, is this a fault with the car? or does it need to be re programmed with the new wheels on?
please help its doing my head in.
LOW RIDER
Old Dec 6th, 2007, 06:03 PM   #2 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 03:18 PM
Online
If you change wheels and tires you need to reset the TPMS.
Old Dec 7th, 2007, 01:19 PM   #3 (permalink)
Randall Raines
MINI & other ½ both whine
Randall Raines's Avatar
DIY Reseting Run-flat indicator light, Tyre Pressure warning light.
Run-flat Indicator light / Tyre Pressure warning light.
Initialising the system, after changing a wheel, tyre, or just doing the pressures (make sure all the tyre pressures are correct), even if the light isn't already on .
Just before you're about to go for a drive, start the car up (don't drive off), press the button (keeping it pressed until the run-flat warning light comes on, then release it) under the hand brake that looks like a cross section of a tyre with a ! in it eg.
If your light is already on it should go of and come back on again (if not already on it should come on), set of on your journey (drive), a few yards down the road it should go off (Reset) .
Mine's the one on the left.
Old Dec 10th, 2007, 08:24 PM   #4 (permalink)
westycoopers
CHEQUE IT OUT
thanks
cheers guys will try both of these
LOW RIDER
tyre pressure warning light grame Faults & Fixes 3 Dec 6th, 2007 06:41 PM
Tyre Pressure Light coded2112 John Cooper Works & GP 3 Mar 6th, 2007 08:02 AM
Tyre pressure light Mini Cruiser Wheels, Tyres & Brakes 4 Apr 5th, 2005 01:03 PM
Tyre Pressure light BritishRacingGreen General Discussion 16 Dec 3rd, 2004 02:13 PM
Tyre Pressure warning light. geonot Faults & Fixes 16 Dec 15th, 2003 08:19 PM
