GizzmoUSA
Tags: , , ,
Old Dec 11th, 2007, 10:43 PM   #1
Hansii
Local Time: 02:21 PM
Door won't stay shut
Me and a friend where going for a drive, but when we got in my car (02 Cooper), he couldn't get the door to stay shut. After countless attempts, we figured out that the door latch thingy didn't lock when pushed in/up. Is this a common problem? It might be due to the cold weather here (-5 C) and the fact that I rarely use the passenger door, after trying a few more times it suddenly worked again.
A couple of weeks ago I had a flat battery after leaving the car for a week, this got me thinking that maybe this caused that, but if the door was open enough to cause the interior light to come on you would think I would notice.
Norway   Reply With Quote
Old Dec 12th, 2007, 03:47 PM   #2 (permalink)
Alexios
are you sure it is the latch and not the window lowering?
hi there
Are you sure it is the latch and not the window lowering properly? I have had this problem sometimes on the passenger side. What you got to do is lower the window a bit and then close the door. Then close the window again. Sometimes the window stays put when frozen and doesn't move down so the door can close properly. That is why I never slam the doors of my mini.
Kunne forklare dette på norsk også.....bor i oslo, frogner hvis du trenger noen hjelp....
Alex
Old Dec 12th, 2007, 04:10 PM   #3 (permalink)
Hansii
Quote: Originally Posted by Alexios (original)
hi there
Alex
I am pretty shure it's the latch, I tried moving it with my fingers and it wouldn't lock, the window was the first thing I thought about, but lowering it didn't help. I haven't dared opening the door since, so it might just have been a temporary problem, but since there are a few design/production flaws with the Mini I figured this might be one of them.
Bor i Trondheim, men takk for tilbudet.
Old Dec 13th, 2007, 12:17 AM   #4 (permalink)
Randall Raines
MINI & other ½ both whine
Randall Raines's Avatar
Local Time: 01:21 PM
I have heard of exterior door handles freezing on earlier MINIs 2001-2004 (this can cause your problem), 2004-Present MINIs have a slightly updated exterior handle (which is supposed to stop them freezing), I would have thought in a country with a lot of frost & snow, these would have been changed on warranty at sometime .
I have also known this happen on UK MINIs when the door lock mechanism has failed / broken and the frost wont help either .
hi there
Alex
This happens on UK cars without the frost (the window stays put (doesn't drop a little)) .
Mine's the one on the left.
Drivers Door Wont stay open! Matthew Boocock Faults & Fixes 2 May 29th, 2007 09:02 AM
Gap in window when door shut - HELP scottp7 Faults & Fixes 7 Jan 30th, 2007 12:50 PM
Glove box won't stay shut RAM Interior & Ice 4 Feb 22nd, 2006 08:04 PM
MCS gas door lock frozen shut Twostep Faults & Fixes 0 Dec 27th, 2002 10:00 AM
Driver's door won't shut! Electric Sheep Faults & Fixes 6 Dec 18th, 2002 01:13 PM
