Visit Mini Mania UK
Tags: , , , ,
Old Dec 26th, 2007, 02:59 AM   #1
sa3dos
Black Cat Owner
sa3dos's Avatar
Local Time: 10:58 PM
Send a message via MSN to sa3dos
Exclamation Clutch serius problem Please Advise
Hello,
I have a 2004 MINI Cooper (Non-S)
Today, my clutch started acting as follows:
  • When you slightly push the clutch pedal, it vibrates (you can feel it with your foot)
  • When you pursh it even further (with windows open), at a certain location, you can hear a squeeqing noise)
  • Later at night, Burning smell inside and outside the car, clutch pedal started acting very different when switching gears
  • 4 min's after the smell, the clutch was completly disengaged, meaning: when I push, it goes 3/4 the way, a cut off, then continues further --> Shifter no longer change position (when clutch is fully pressed).
  • Since my MINI can only switch on when the clutch is fully pressed, this function is O.K.
Car is towed to nearest BMW dealership and will be looked at after two days due to the holidays (Happened this christmas eve, driving back home for nice family dinner, you can imagen how unlucky i was )
Any knowledge of what kind of problem am I expecting? can you also elaborate as why so?
Canada Male View sa3dos's Solid Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Dec 26th, 2007, 08:32 AM   #2 (permalink)
M111 CGC
Mini Madness
M111 CGC's Avatar
Local Time: 03:58 AM
Send a message via MSN to M111 CGC
Sounds like your Clutch release bearing has failed?
2007 Clubman Cooper D ~ 2004 Cooper S JCW
United Kingdom Male View M111 CGC's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 28th, 2007, 05:44 AM   #3 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
buy a new one, it's goosed !
I'm sure i said this before. Seems that someone doesn't like my blunt posts.
Cheers,
K.
Old Dec 29th, 2007, 03:01 PM   #4 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
I also think bearing too which has probably cooked the friction surface now too if it smelt that bad. Hope you get it sorted quick
Old Dec 29th, 2007, 10:28 PM   #5 (permalink)
Lawrothegreat
Mini Design Philosopher
Lawrothegreat's Avatar
I had a 2004 Cooper which had a clutch fail twice. Both times there was a slightly broken feel to the pedal with noticeable vibration, but the operation was fine. The first time I was told it was a thrust (release) bearing, the second time the slave cylinder.
Old Dec 30th, 2007, 12:12 AM   #6 (permalink)
Bilbo Baggins
Bilbo Baggins's Avatar
With the strong smells you discribe it sounds as though the pressure plate might have also failed. Did it still feel solid as though it was not slipping or was it difficult to get going? When you stepped on the gas did you pick up speed as quickly as you normally would have?
Good luck. Keep us informed.
'06 MCS SB/S R84s(Dunlop 5000, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
S ordering problem - advise needed! cf302 2nd Gen MINI Cooper S 2 Aug 15th, 2007 06:56 AM
New JCW head valve lifter problem - Advise please (Roland?)! BlueMax Engine & Drivetrain Tuning 7 Jul 20th, 2006 11:14 AM
possible clutch problem? shrekone Faults & Fixes 2 Jul 27th, 2005 10:24 PM
could this be a clutch problem baha General Discussion 4 Jul 24th, 2005 07:25 PM
O5 MCS with clutch problem Rossi Faults & Fixes 14 Sep 11th, 2004 09:11 AM
