Visit Lohen!
Tags: , ,
Old Dec 27th, 2007, 09:47 PM   #1
leonB10
Local Time: 02:16 AM
Problem with 2001 Cooper, EML wont rev above 2000rpm
Hi all,
New to the forum, I have been searching but cant find anything on this problem so hopefully someone can help. I am having a problem with my girlfriends 2001 Mini Cooper. Its an intermittent fault but is becomming more common now. When the car is started the EML light stays on and the car idles very roughly, like its misfiring and it wont rev above 2000rpm. I presume this is some sort of limp mode it is going into. if the car is continually switched off and restarted it will eventually stop doing this and be normal again. There doesnt seem to be a distinction between the car being cold or warm. I have changed the plugs and leads with genuine BMW/MINI Items as part of an oil and filters service and this didnt make a difference. We did notice that when the car is cold and this happens the coolant temp gauge goes up a towards 1/4 way even though the engine is completely cold.
Has anyone experienced this before? I was considering replacing the coil pack next but I was under the impression that coil packs either work or dont and not intermittently so dont think its this at all. I read on here somewhere about a software upgrade and I dont know if the car ever got one. I have the B100 scan tool but when I try looking for a fault code, it keeps throwing up a Error message. I am not sure if this scan tool works with the mini.
Any suggestions appreciated.
Ireland   Reply With Quote
Old Jun 19th, 2008, 08:42 PM   #2 (permalink)
sledge
Local Time: 04:16 AM
Did u manage to sort out this problem? i have the same problem.
South Africa   Reply With Quote
Old Jun 20th, 2008, 01:21 AM   #3 (permalink)
oldmots
Local Time: 10:16 PM
This car needs to go on the scanner at the dealer, it may have a software or loom fault and nothing else is going to fix it if this is the case. The behavior of constantly rebooting fixes it is the key. The only thing you can do is to load test (not voltage test) the battery and make sure it has the ampacity to run the car, if it is low, it can cause the software failure. The reflash job is not real expensive compared to chasing the problem in the driveway with only your wallet to throw at it!.
Old Jun 20th, 2008, 08:34 PM   #4 (permalink)
mini-millie-n-dan
Local Time: 03:16 AM
I have had similar problem with mine, EML would come on while driving, also missing on start up at times an not rev. over 2000. Had the codes read at a friends garage and all connected to throttle body. Put a 2nd hand throttle body in last weekend (£10 off ebay) and the car has run ace all week!!! It's covered 100+ miles this week so problem sorted (touch wood).
Hope you get it sorted soon
2001 Cooper Power Loss SamHarrison Faults & Fixes 1 Oct 14th, 2005 02:09 PM
Will Cooper S 2005 seats fit in a 2001 Cooper? teeman Interior & Ice 0 Jun 15th, 2005 08:30 PM
FOR SALE: 2001/51 Cooper gazzaman28 For Sale 2 Nov 10th, 2003 01:42 AM
2001 MINI Cooper, 51 reg Crashandburn For Sale 9 Jul 1st, 2003 10:34 PM
For Sale - 2001 Cooper (UK) hunty For Sale 0 Dec 27th, 2002 03:52 PM
