Visit Out Motoring!
Tags: , ,
Old Jan 11th, 2008, 09:25 PM   #1
theminiv
theminiv's Avatar
Local Time: 11:58 PM
Yet another gearbox issue . . . .!!!
Hey all, I recently went to my dealer with a slight intermittent knocking noise coming from the clutch when I release it. This noise will also be there when I slow down in a high gear just before putting the clutch in. As the engine goes to about 1000 rpm, the slight knock occurs.
They said it was the gearbox, so they replaced it. (20000) miles. - Got the car back, its a 2006 mini one, so a gertrag box. Now the reverse gear goes in without any grinding??!?!! Have they modified it??
But the worst thing is, the knocking noise when lifting the clutch is still there!!!! - I not taking it again until its next service, but what could this be??!!
Also just for info. Although my gearbox was replaced under warranty, value of the work was £2500 TRADE!! Ouch!
Any info would be appreciated.
Focus > Mini One > Mini Cooper > Mini Cooper > BMW 316 > BMW 318 > MINI ONE > BMW 120i > MINI ONE PEPPER! - IM BACK!!
Old Jan 12th, 2008, 02:51 AM   #2 (permalink)
oldmots
Local Time: 06:58 PM
It might be the dual mass flywheel dampers knocking. There have been many problems with these. Your flywheel has two metal flywheels with a friction material between them and dampers to soften the engagment motion. If the friction material wears or the dampers go bad, you will get knocking or scraping noises.
Old Feb 5th, 2008, 07:29 PM   #3 (permalink)
David King
Captain Slow
David King's Avatar
Mine went in today for a knocking clutch noise. They rang me up and said "we are very unhappy with the noise, so we are going to take the gearbox out to further diagnose the problem."
He said it could just be a simple new clutch job (covered under warranty)
I will let you know what they find it out to be.
United Kingdom Male View David King's Royal Grey & Silver 1st Gen MINI Cooper Profile   Reply With Quote
Old Feb 5th, 2008, 10:10 PM   #4 (permalink)
Jaw_F430
Jaw_F430's Avatar
Had mine done on my MCS not too long ago, it was the clutch and flywheel that was replaced under warranty and all sorted. There are a few threads on here about it and its a known fault to BMW.
Kocking noise when clutch out, press clutch in and it goes away. Thats what mine was doing
Hope this helps
Regards
James
United Kingdom Male View Jaw_F430's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 6th, 2008, 11:25 AM   #5 (permalink)
1320autos
1320autos's Avatar
One and Cooper doesn't have a dual mass flywheel.
IT'S NOT HOW MUCH YOU SPEND BUT HOW WELL YOU SPEND IT
Old Feb 7th, 2008, 04:54 PM   #6 (permalink)
David King
Captain Slow
David King's Avatar
Well ive just got back from picking the car up, they said its had a new clutch and flywheel fitted. Seems to have done the trick.
GearBox Issue / Thrust Bearing JCW225 Maintenance & MINI Care 4 Oct 18th, 2007 02:35 PM
MC2 issue 6 velveteen_mini Canada 13 Feb 12th, 2007 03:54 PM
Gearbox / clutch issue DurhamFox Faults & Fixes 5 Sep 5th, 2006 04:40 PM
My cold start issue is now a warm start issue FrenchCori Faults & Fixes 0 Mar 31st, 2006 10:39 PM
gearbox/trans issue The_length Faults & Fixes 1 Mar 6th, 2006 10:48 PM
