| Tags: windscreen |
| MINI2 Newbie | im getting a lot of wind noise coming into my mcs 05 when im on the motor way and the oter day i got what i can only explain as high pitch wailing noise from my windscreen when i was travelling at around 70 mph plus i took it to my dealers who said it was the wiper motor and they replaced it under warrenty but my car is still very wind noisey the high pitch noise i havent heared yet but its not been very windy where i live since they fixed my wind noise plus ive not driven it for a week as ive picked up for work has anyone else had the same problem??? |
| MINI2 Newbie Join Date: Aug 2006 Location: Leicester Local Time: 11:05 AM
Offline | I think I have the same problem as you do. When going at high speed on the motorway I get a high pitch note which appears to come from behind the built in Sat Nav. It only started after I had it serviced and the first time it happened it was pretty windy anyway. Does the sound kick in at a certain speed or does it gradually increase? At first I thought it was an electrical problem as the sound is so strange but wailing and high pitched is a pretty accurate description. I was going to drop it into the dealer to investigate but am concerned that as it only kicks in around 85 they will not be willing to look at it. Can you report back on whether changing the motor fixes this? Thanks |
| MINI2 Newbie Join Date: May 2008 Location: Warwickshire Local Time: 11:05 AM
Offline | This is also a problem that i am having. It doesn't do it all the time. When it does it starts usually around 70mph, then doesn't go away unless i slow back down. It is the worst noise ever heard. I have tried turning random things on and off - such as air recirculation, but to no affect. It has also been suggested that the windscreen pillar caps may be lose - one did come off but it is now siliconed back on so don't think it is this. I am sure it is coming from the windscreen, but thats as much as i can tell. If you guys figure it out, let me know. Cheers Chris xx |
| | #6 (permalink) |
| MINI2 Newbie Join Date: Oct 2007 Local Time: 10:05 AM
Offline | Hi fellow mini fans I had this problem on both current mini and previous mini(both R53's 52 and 06 model). I found a fix by having the windscreen resealed. If you have the same trouble as I did, the noise is at motorway speed. Try check this by getting a passenger to slightly press against the inside of the windscreen when the awful screaming starts. The noise will stop if you have the same problem as I did. If this is the case the deal should reseal the screen under warranty. hope this helps ![]() |
| 3rd Windscreen ? | p0jy | Maintenance & MINI Care | 5 | Dec 17th, 2007 03:41 PM |
| Windshield (or for the Brits windscreen) noise.....?? | SiNNeD | Faults & Fixes | 5 | Feb 11th, 2005 10:54 PM |
| CVT Noise (Pressure Release Noise?) | tog255 | Faults & Fixes | 2 | Sep 10th, 2004 04:46 AM |
| noise noise and more noise (wheel bearings?) | eddie_DV52_CCZ | Faults & Fixes | 2 | May 22nd, 2004 10:28 AM |
| Replacement Windscreen Noise | jontyb | Faults & Fixes | 0 | Oct 12th, 2003 04:20 PM |
