| Tags: rear, wash, wipe |
| MINI2 Newbie Join Date: Feb 2008 Local Time: 11:07 AM
Offline | rear wash wipe not working? Hi, I am new to the forum so hi to you all ![]() I have just bought an 04 plate mini one, the car is lovely... just one problem, the rear wash wipe isnt working, when i put the washer on it makes a noise near the bottle but nothing comes out of the back washer....yet the front works NP..... is this a problem with these cars? Tara |
| MINI2 Newbie Join Date: Jan 2008 Local Time: 11:07 AM
Offline | Rear Wash Wipe Not Working Hi I have a 2002 Cooper and had the same problem with the rear washer not working. There are two parts, the wiper and a cap which covers the connection between the wiper and drive shaft. Do four things:- 1) Pull the cap gently towards you to remove it. 2) Run the washer to clear any muck in the feed pipe, you should see a good stream of water jetting out. 3) Clean inside the cap. 4) Reassemble. I hope this helps. Stez |
![]() Skadoosh! | Sometime the rear washer gets blocked. You can unblock this with a pin. ![]() With regards to the speed settings for the front wipers, there should be three settings. Up once for intermittent. Up again for normal wiper speed and then up again for the fastest setting. Pressing down from the initial position will make the wipers wipe once. ![]() |
| Removing Rear Wash Wipe Question. | Merlin 2 | Exterior | 10 | Jun 7th, 2008 11:16 PM |
| Rear Wash wipe filter | ALD0 | General Discussion | 3 | Dec 21st, 2007 02:45 PM |
| Problem with Rear Wash Wipe | JamesK1975 | Maintenance & MINI Care | 4 | Dec 9th, 2007 06:00 PM |
| Works GP rear wash wipe.... | Tonyt3 | John Cooper Works & GP | 25 | Oct 2nd, 2006 08:07 AM |
| Rear Wash/Wipe Problem | AntH | Faults & Fixes | 1 | Apr 9th, 2003 12:29 AM |
