Performance Torque
Old Feb 26th, 2008, 09:15 PM   #1
DublinChris
Local Time: 12:11 AM
DIY gurgling sound
New to forum can I get some advice. Have 06 Cooper Parklane. Car has started to make gurgling sound which appears to be coming from passenger side around glove box. I assume it is to do with heater/coolant. Don't appear to be losing any fluid. Can anyone advise what is going on. Car has 14K miles
Old Feb 26th, 2008, 09:19 PM   #2 (permalink)
LMB
Toon Toon..
LMB's Avatar
I heard the same noise on my Mini. I don't think it's anything to worry about.
Welcome to Mini2 btw.
Global Moderator
England Male View LMB's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 26th, 2008, 09:24 PM   #3 (permalink)
Fevs
heading north !!!!
Fevs's Avatar
Send a message via AIM to Fevs
mine was doing it mate keep an eye on ya coolant its air in the heater radiator as the coolant level is dropping
had it on all on my mini's now
ended up having the thermostat housing replaced on my 06 cooper just as taht was the fault
Global motivator
England Female   Reply With Quote
Old Feb 26th, 2008, 09:33 PM   #4 (permalink)
DublinChris
Pure Silver gurgling sound
Thanks guys had an idea it might be air getting in. Can it be bled or is it just a matter of topping up coolant? IT'S kind of an annoying sound more noticable when starting from cold as I assume level is lower and then when car heats up the coolant expands and sound goes. It just that it sounds like water sloshing around initially.
Old Feb 26th, 2008, 09:36 PM   #5 (permalink)
Fevs
heading north !!!!
Fevs's Avatar
keep an eye on the levels top up as needed it will go when it bleads its self out there is a bleed screw just infront of the rocker cover free end of the engine
Global motivator
Old Feb 26th, 2008, 09:57 PM   #6 (permalink)
DublinChris
Thanks again. Just been off looking at all the posts back to 2002 on the same topic!!
If this was the central heating in the house I would be bleeding the system! Dont know about the rest of you but I find it a bit annoying in what is a great fun car to drive - lots of character. Oh I should say it's actually the wifes car!! I just take it now and again to stretch it's legs and blow the cob webs off.!
Old Mar 6th, 2008, 10:46 PM   #7 (permalink)
Mini_Tech
Local Time: 11:11 PM
this is caused by a poorly bled coolant system. air gets caught around the heater matrix inside the dash, the pipes into the engine bay are in the passenger footwell. check your coolant levels are correct, set your heater to hot, fan to 3 and air direction onto the windscreen. Then start the engine, and hold the revs at around 3k till the air blows HOT from the top dash vents. Give it a few good hearty revs to about 5.5k and your problem should be solved! Dont forget to recheck your level once its cooled! Hope this helps
-Paul.
Aircon gurgling & graunching sound? ocoro02 Faults & Fixes 0 Feb 10th, 2008 03:37 PM
Gurgling, water sloshing sounds...... Tracie Faults & Fixes 26 Mar 1st, 2006 06:58 AM
Gurgling sound at startup? Dublin Guy General Discussion 4 May 10th, 2005 11:14 AM
s sound boothy MINI Cooper S 10 Aug 26th, 2003 06:33 PM
Gurgling sound jeff90 MINI Cooper 6 Nov 15th, 2002 01:01 PM
