Mini Pirate
Old Mar 8th, 2008, 06:46 PM   #1
ellclover
Local Time: 11:09 PM
only 6psi of boost
ive been thinking for a while that my mini cooper s 2002 52 reg wasnt as fast as it should be so i fitted a boost gauge to see what it boosted and it only boost 6 psi and that is it all the way to the red line. can anyone tell me what it could possibly be thanks elliot
Old Mar 9th, 2008, 01:44 PM   #2 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Belt slipping big time, boost leak somewhere probably the intercooler, bypass valve shockingly adjusted or the boost gauge is plumbed wrong?
You need a nice pulley on there too.... it will run nice at 16-18psi
Old Mar 9th, 2008, 04:18 PM   #3 (permalink)
ellclover
hi there well if im honest with you i only checked boost because i was fitting a new pulley today.
ive put on a 15% reduced pulley with a cooper s works belt of 1374mm so its definently not slipping now ive tried cable tying the bypass valve both ways and on one way it felt the same and the other way it didnt run at all
im now running 10psi of boost with the new pulley which is still really low the boost gauge is fine because it has been in a friends car reading correctly and the pipe has only been run through my window as a temp so that is fine. the car feels alot better now but i think it could be even better again
cheers
Old Mar 9th, 2008, 06:26 PM   #4 (permalink)
MINI-Morgan
MINI Obsessed...
How much does the gauge read at idle?
Didnt run at all?? You mean no boost at all? It doesnt matter if you cable tie it shut if its not adjusted correctly as you are still pulling against the same grub screw. Wind it out half to one full turn and see if it makes any difference.
Have you double checked the intercooler clamps? Sometimes the rubber actually splits where it bends and isnt obvious.
Old Mar 9th, 2008, 06:47 PM   #5 (permalink)
ellclover
i will try that tommorow after work! but surely that would been that it has only been boosting low since new? i will look for a leak and see what i can see. ive had a few turbo cars which i was just getting used to fault finding with and now this super charger is a totally different game. thanks for your help i will let you no how i go on.
cheers
Old Mar 15th, 2008, 06:47 PM   #6 (permalink)
ellclover
well this weekend ive took the car to pieces and still cant find a leak. ive been using gas leak spray and looking for bubbles, but nothing. ive had my throttle body off and by pass valve, and even adjusted the bypass valve to make it close tighter! still nothing any other ideas?????
please help cheers
Old Mar 15th, 2008, 08:23 PM   #7 (permalink)
MINI-Morgan
MINI Obsessed...
Did you cleck the intercooler seals like I suggested? I changed back to stock intercooler and had a major leak caused by this myself......
Old Mar 16th, 2008, 10:10 AM   #8 (permalink)
ellclover
yes the intercooler seals are fine ive even checked them with gas leak spray to see if there was any bubbling and nothing! could the charger be on its way out?
Old Mar 16th, 2008, 12:05 PM   #9 (permalink)
MINI-Morgan
MINI Obsessed...
Gas leak stray? Fairy liquid but 40times more expensive? I'd be amased if it will tell you anything being too light for the air flow that you would experience.
Does the boost go up as you open the throttle but it reaches a point (6psi) and then drops a bit again and you can hear a blowing sound?
I hope you are testing with your foot flat to the floor as this cant be tested on a drive way very easily.
Also are you seeing negative between -8 and -14psi at idle? (if I have converted that correct.... I always work in absolute pressure instead)
Old Mar 16th, 2008, 12:23 PM   #10 (permalink)
MINI-Morgan
MINI Obsessed...
Just thinking and really there is only so many places it can be.
1) Bypass valve and connections
2) Blocked inlet track e.g. filter
3) Supercharger seal
4) Intercooler seals
5) Manifold seals
6) vaccumm hose from supercharger
7) Vaccum hose from the intercooler clam
Since its failing to reach 10psi im betting on being one of 1,2,4,6 or 7.
Leak chasing for boost pressure isnt easy when you cant be looking while its at full boost unless you have a rolling road.
Or the leak is your boost gauge!
Old Mar 16th, 2008, 12:47 PM   #11 (permalink)
ellclover
can i just say thanks for your help upto yet, because you are the only person who has replied
1)i have checked the bypass valve and put new jubilees on the connections that is fine
2)i have a newish k&n on so i dont think its that
3)how would i know if it was this?
4)intercooler boots are sealed perfect im sure of this
5) one of the last things i would like to be checking really lol
6) where is this??
7) and again where is this?
the car has done nearly 90k so am i wrong in saying in could be the charger???
thanks again morgan for your help!
Old Mar 18th, 2008, 01:13 PM   #12 (permalink)
MINI-Morgan
MINI Obsessed...
6) where is this??
3) Just check all the bolts are done up firmly
6) is shown in the first image
7) shown is second image
It could we be the charger but just suprising if it is....
Name:	P3101179 (Large)2.jpg
ID:	143719  Click image for larger version
Name:	P3101159 (Large)2.jpg
Changing a 2003 Boost Stereo to an 2005 Boost MP3 Stereo futureal33 Interior & Ice 1 Nov 28th, 2006 08:40 AM
upgrade your wave or boost casette player to boost CD bcoxeter For Sale 12 Dec 14th, 2005 04:21 PM
Boost Cass --> Boost CD upgrade (HK fitted) john_o Interior & Ice 0 Jan 10th, 2005 07:36 PM
Here is what i'm getting for BOOST presurized mini Engine & Drivetrain Tuning 28 Aug 21st, 2003 05:29 AM
How good are boost/non boost cd systems ? smartbomb Interior & Ice 11 Dec 31st, 2001 01:14 PM
