Performance Torque
Tags: , ,
Old Mar 15th, 2008, 05:32 PM   #1
Fabio
F43i0
Fabio's Avatar
Local Time: 11:06 AM
Send a message via MSN to Fabio Send a message via Skype™ to Fabio
a couple of lights on my ........ and a leak
my speedo wont turn off
The Emissions light and the DSC light turn are constantly on(both yellow), they just decided to come on yesterday .....just remembered that the battery turns on also (red)
Also the exhaust is popping alot more than usual and the car doesnt idle well . The revs have now started to drop right down and the cars shuts off ,then the EML and engine OIL light turn on(both red). I just switch it back on and it'll be fine until the revs drop again i.e. at traffic lights
Also noticed that while on the motor way and lets say in 3rd gear and i'm at 5000rpm and take my foot off the accelerator the car jerks, like the engine break over works
DSC seems to still work while the light is on
any ideas??
cheers
btw its booked into dealers early next week
Old Mar 15th, 2008, 06:32 PM   #2 (permalink)
richg40
sounds like throttle connector resistance problems at a guess. probably need an engine wiring harness.
Everyone else is lying to you. stop giving out duff advice people!
Old Mar 15th, 2008, 06:35 PM   #3 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Loose connection or a wire earthing maybe??
I'm sure the ECU and BC1 fault codes will shed some light for the dealer
Old Mar 15th, 2008, 06:52 PM   #4 (permalink)
Fabio
F43i0
Fabio's Avatar
cheers, hopefully its not too serious!
Old Mar 15th, 2008, 07:44 PM   #5 (permalink)
ButtonIt
The Disorganiser
ButtonIt's Avatar
Send a message via MSN to ButtonIt
By the sounds of that though, i wouldn't drive it mate Call out MINI assist
England Male View ButtonIt's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 15th, 2008, 09:09 PM   #6 (permalink)
Fabio
F43i0
Fabio's Avatar
have it in the garage, didnt get a chance today and was late yesterday when it happened
i only live 2km from dealer, so i'll drop it in on Tuesday
Old Mar 16th, 2008, 03:18 PM   #7 (permalink)
Fabio
F43i0
Fabio's Avatar
there seems to be a leak coming form underneath the passenger side of thecar, i moved the car back and forth and saw it , its not oil....any ideas
Old Mar 16th, 2008, 07:25 PM   #8 (permalink)
MINI-Morgan
MINI Obsessed...
Old Mar 16th, 2008, 07:25 PM   #9 (permalink)
MINI-Morgan
MINI Obsessed...
Old Mar 16th, 2008, 07:31 PM   #10 (permalink)
Fabio
F43i0
Fabio's Avatar
How do you know its not oil?? Hope its not brake fluid!
it seem'd to dry up and didnt leave a stain on the ground
dont think its brake fluid, its more of a water based substance,
Is there some fluid in the lsd?
Old Mar 16th, 2008, 08:54 PM   #11 (permalink)
MINI-Morgan
MINI Obsessed...
The LSD uses the gearbox oil.
Sounds like water from the cooling system........
Old Mar 17th, 2008, 09:06 PM   #12 (permalink)
oldmots
Local Time: 06:06 AM
Sounds like a bad battery to me. I would check it and also read the obdII codes.
Old Mar 18th, 2008, 10:24 AM   #13 (permalink)
Scourgebk
Local Time: 06:06 PM
Not sure but it could be water leaking and short circuiting your body control module as everything seem to go haywire. Was it raining before this happened?
Try this... disconnect your batteries for a good few hours and allow the system to reset (this also allows the residue water to dry up). While this will work, you need to find out what exactly happened to prevent further damage to the body control module.
My 2 cents...
Malaysia Male   Reply With Quote
Old Mar 18th, 2008, 11:07 AM   #14 (permalink)
Fabio
F43i0
Fabio's Avatar
cheers for the advice , i'm gonna leave it to the dealers now......
it was raining, but it rains most days over here!!!
Old Mar 19th, 2008, 10:02 AM   #15 (permalink)
Rakey
I am not a number!!
Rakey's Avatar
Had the DSC light stay on in mine, was a faulty brake sensor which got replaced by Dealer under warranty
Its only a forum you know!
Old Mar 19th, 2008, 11:52 AM   #16 (permalink)
Fabio
F43i0
Fabio's Avatar
i'm not too worried about that light, its the other ones that worry me
brought it in yesterday tothe dealers but havent heard anything yet, cause was originally booked in for today, it didnt feel right on the motorway on the way up
Old Mar 19th, 2008, 05:42 PM   #17 (permalink)
Fabio
F43i0
Fabio's Avatar
problem solved......
it was a fuel pressure sensor...replaced and the i've just got home, car is going as great as ever
i was worried for a few days
Old Mar 19th, 2008, 08:05 PM   #18 (permalink)
richg40
fuel pressure sensor? never, ever seen that before.
Old Mar 19th, 2008, 08:27 PM   #19 (permalink)
Fabio
F43i0
Fabio's Avatar
yep, thats what they told me
Old Mar 19th, 2008, 08:28 PM   #20 (permalink)
oldmots
The car has no fuel pressure sensor, it was likely the manifold absolute pressure sensor, which would cause the problems you have in that it sets mixture. There is a fuel pressure regulator on the injector rail. A problem with this could also affect idling and running but it is not a sensor.
Spot lights, a couple of questions Alex5 Exterior 4 Feb 18th, 2007 11:38 AM
a couple of questions on clear lights/installation thebaron Exterior 2 Sep 5th, 2004 06:50 PM
A couple of questions on lights... LOUD little MINI Exterior 6 May 15th, 2003 10:24 PM
