Performance Torque
Tags: , ,
Old Mar 24th, 2008, 03:21 PM   #1
drainaudio
BRG S w' all the toys..
drainaudio's Avatar
Local Time: 01:18 PM
Clicking noise, driver's side, getting worse..
Hi all,
Have been trying to locate a low pitched clicking noise that seems to be coming from the drivers side wheel arch area.
Initially it was present when accelerating/decelerating at low speed (stop/start traffic scenario) and sounded almost like a light switch being turned on and off.
Dealership investigated and found play in the seat rails which they replaced but the problem persisted.
Over the weekend I've now heard the same clicking noise but in rapid succession when driving over very rough tarmac at a low speed.
Anyone have an idea of what this might be?
Doesn't sound like a shock absorber knocking, seems possibly more like a CV joint noise to me but can't be sure.
Doesn't happen when I drive it like I stole it, clicking noise only occurs at low speed.
Cheers, Geoff.
United Kingdom Male View drainaudio's British Racing Green & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 24th, 2008, 05:59 PM   #2 (permalink)
*Vikki*
Winner MM best MINI ONE!
*Vikki*'s Avatar
hmm lots on here now asking this question, have a search my guess it sounds like lower steering spindle, or rack going?
Old Mar 24th, 2008, 06:15 PM   #3 (permalink)
minicabrio
Back in a MINI
minicabrio's Avatar
Online
Had the same problem on my Cooper - well it sounds like the same problem.
If you're sat in traffic, every accel/decel movement produces a click?
Barons diagnosed the fault as a driveshaft within about 30 seconds of me demonstrating the fault - car was booked in, driveshaft replaced under warranty and the click never returned.
Old Mar 24th, 2008, 11:19 PM   #4 (permalink)
drainaudio
drainaudio's Avatar
Hi,
Thanks for the heads up on this, I did a bit of searching of the forums after my post and found that several people have had the same symptoms and a drive shaft replacement has cured the problem.
Thought I was hearing things until driving over some rough tarmac 2day and hearing it a lot.
Will call workshop 2moro morning - thank goodness I found a good one I can walk to and took out that Mini extended warranty (as mine expired 1 week ago )....
- supercharger whine.......supercharger whine.......supercharger whine..
I wonder if they can revoke the extended warranty?
I do love this car, incredible design and a smile on my face every time I drive it but it's just silly how many "little" things constantly need attention..
Is it BMW engineering or where they're assembled I wonder..
Cheers, Geoff.
Old Mar 27th, 2008, 08:11 AM   #5 (permalink)
baskers
baskers's Avatar
Sounds like a wheelbearing - so get them to check that too. That's what mine was.
Old Mar 28th, 2008, 02:16 AM   #6 (permalink)
drainaudio
drainaudio's Avatar
Update..
They went right through the driver's side suspension and finally.......yep it's a drive-shaft issue..
*loody Cooper S, it's only done 17k!!
Supercharger Whine...........Supercharger Whine............
Old Mar 28th, 2008, 03:01 AM   #7 (permalink)
MINIMANIAUK
MINI2 Sponsor
Online
and they replaced a seat rail first? sound like my plumber ; after a sharp intake of breath "you need a new boiler" ; One day I might actually need a boiler so far not!
Old Mar 28th, 2008, 08:29 AM   #8 (permalink)
minicabrio
Back in a MINI
minicabrio's Avatar
Online
Quote: Originally Posted by drainaudio (original)
Update..
Good news
Old Mar 29th, 2008, 05:31 AM   #9 (permalink)
drainaudio
drainaudio's Avatar
Ok, so now with the new drive shaft installed...............yep, that's not it either (apparently)
So now they are replacing an engine mount also and I have to wait another day..
Oh well, good thing I don't actually need a car to commute etc and I can walk to the workshop.
Looks like I'll be making good use of the extended warranty - *** it.......these cars are way too expensive to have so many silly problems all the time - they can keep fixing it until it's right..
It's done 17,000 pampered miles - barely out of the box..
I love driving the S, it's a brilliant car when it's all working, probably why Mini owners are so forgiving..
I wonder however if the Mini was just a bog standard small hatch how quickly they'd go out of business.
Before I bought my first Cooper in Dec 05 (almost new) I had an absolutely mint 1993 Mercedes 190E, it was 12 years old, purred like a kitten, not a rattle or squeek in sight and other than routine servicing required nothing - then I got into Mini's and between the Cooper and the S I've never visited a workshop so often
Cheers, Geoff.
Old Mar 29th, 2008, 06:45 AM   #10 (permalink)
M111 CGC
Mini Madness
M111 CGC's Avatar
Send a message via MSN to M111 CGC
Are you sure there's not someting simple like a stone stuck in the tyre tread? When I first put F1s on my Cooper S I had a clicking sound which was some gravel stuck in the deep tread and clicking each time the wheel went around.
Chris
2007 Clubman Cooper D ~ 2004 Cooper S JCW
United Kingdom Male View M111 CGC's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 29th, 2008, 04:13 PM   #11 (permalink)
drainaudio
drainaudio's Avatar
Chris
A stone in the tyre tread would cause a click every single time the wheel rotated and would increase and decrease with the speed of the vehicle.
These are not the symptoms I'm experiencing but thanks for the suggestion
Help locating clicking noise from drivers-side pls? drainaudio Faults & Fixes 3 Jul 22nd, 2008 03:30 PM
Clicking noise!!! phil_c 2nd Gen Faults & Fixes 1 Aug 28th, 2007 07:41 PM
Clicking noise turning right Gr1zzLy Wheels, Tyres & Brakes 4 Apr 11th, 2007 10:34 PM
Loud Clicking Noise RussT Faults & Fixes 2 Apr 20th, 2006 08:57 PM
Clicking noise under load Mike Yue Faults & Fixes 3 Jul 20th, 2005 09:53 PM
