| Tags: power, steering |
| MINI2 Newbie | power steering ?? and strange noises guys, how does the power steering work on the r53 cooper s? i noticed there is no power steering fluid resevoir and doesnt seem to be any information in teh manual???? basically iv noticed a slight whinning noise if you turn the steering wheel at full lock any ideas or is this common? thanks |
| MINI2 Senior Join Date: Jul 2007 Location: 7600rpm Local Time: 03:49 AM
Offline | Yes the noise is common, there is a PAS fluid resevoir under the bonnet, without going to look I think its black ![]() See here:RealOEM.COM * Part Category Selection |
| MINI2 Senior Join Date: Nov 2006 Location: London Local Time: 03:49 AM
Offline | The MINI power steering is unusual because it is "electro-hydraulic" with a fluid reservoir (central at back of engine compartment near bulkhead) but the pump providing pressurised hydraulic fluid to the steering rack, is driven by an electric motor instead of being belt driven off the engine like most other cars. The electric pump motor is what gives the distinctive whining noise on turning but I have grown to like it ! ![]() Many other small cars including the latest R56 MINI now use fully "electric servo" power assisted steering with a motor geared direct to the column or steering rack with no hydraulics or fluid reservoir and less noise. Both types of electric power steering are used on small cars because there is no power drain* from the pump being driven by the engine and this also means marginally better fuel economy. The system is powered by electrical current being drawn from the vehicle's electrics. They have a built-in safety device so that if the electrical power supply were to fail, then it will default to a conventional un-assisted steering system. Additionally, if the engine was to stop whilst the car is moving then the fully electrically assisted steering system will still operate, unlike a conventional hydraulic assisted system. However as some MINI owners have found out if the electric motor fails on the electro-hydraulic system the steering does suddenly get very heavy ! ![]() * Note: A few years back the smaller engined Ford Fiestas were offered with a choice of Power steering or Air Con but not both as the power losses to drive both pumps off the engine was just too great. |
| Strange goings on and noises from dash | ego3 | 2nd Gen Faults & Fixes | 4 | Dec 31st, 2007 06:34 PM |
| Steering Noises, Accel Noises, and others | tbonecopper | Engine & Drivetrain Tuning | 4 | Mar 28th, 2006 11:26 PM |
| strange noises + wheel alignment | The Saint | Faults & Fixes | 3 | Aug 1st, 2005 01:05 PM |
| Strange noises from Harmon Kardon | ~Marcus~ | Interior & Ice | 3 | Jan 20th, 2005 10:30 PM |
| Strange Noises | Jupiter | Faults & Fixes | 1 | Sep 2nd, 2004 09:01 AM |
