| MINI2 Regular Join Date: May 2002 Local Time: 07:13 AM
Offline | @#$#@!! Well, I just pulled my MCS out of my garage, and noticed a puddle on the floor. I popped the hood, and found what appears to be coolant all over the heat sheilds. Great... just great. Only 2100 miles. The coolant tank also appears to be just about empty. When the car was cool, I totally wiped everything down and then took it for a 2 mile ride. Now the entire area is wet with burning coolant. It appears to be (my guess) coming from the seam on the coolant tank. Last edited by Rich_W : Sep 22nd, 2002 at 10:29 AM. |
Offline | Now my question is... Should the car be driven low on coolant? And considering the fact that its making a mess inside my new car's engine compartment. The tank appears to be just about empty. |
| MINI2 Master Join Date: Jul 2002 Location: Florida Local Time: 02:13 AM
Offline | Do not drive your car low on coolant or with no refrigerant at all. You are risking doing serious damage to your engine!. Call MINI's roadside assistance and have the car towed back to the dealership ASAP. ![]() '02 MINI Cooper CVT On Order: 2004 MCS (Est production date: 9/5/03) |
| | #6 (permalink) |
| MINI2 Newbie Join Date: Jul 2002 Local Time: 02:13 AM
Offline | My Cooper was/is leaking coolant at a VERY slow rate. It's slowed down to about a millimeter per week on the reservoir tank. It lost about 2-3 inches in the first 800 miles. My dealer tried to tell me that I've got to add coolant every 3 or 4 months because it evaporates. I think he's on crack. It's a closed system, so any coolant that vaporizes will condense within the system. ![]() |
| | #7 (permalink) |
| MINI2 Master | Could the coolant go down during break-in? Mine doesn't seem to be losing but it is above the MIN mark but not right between MIN and MAX so I wonder if it lost a bit during break-in. I'm keeping my eye on it and the oil (since it is down below the midpoint of MIN and MAX too) and will add to both or either as required. Has your dealer done a pressure test? If it is just losing a tiny amount then it will be difficult to look for leakage, or I imagine it would be difficult. Harry MINI Cooper Cabrio: now the car with go cart handling really feels like an open go cart! "... the only man that can come home at 3 am in the morning without getting into trouble with his spouse is the owner of a British sports car!" -- Phil Bailey |
| | #8 (permalink) |
| MINI2 Newbie Join Date: Sep 2002 Local Time: 07:13 AM
Offline | 1) The engine should NOT use any coolant due to breaking in. 2) Your coolant is NOT evaporating. The problem is related to the "less than great" little clamp on the bottom of the coolant fill bottle. Replace this clamp with a good screw type clamp and your leak will be gone. :-) - Chris |
| | #9 (permalink) |
| MINI2 Senior Join Date: Jun 2001 Location: USA Local Time: 07:13 AM
Offline | Actually the "coolant" can evaporate a bit since it is composed of a mix of antifreeze and water. The coolant recovery tank is vented to the atmosphere and there can still be some vapor leakage around the radiator cap. But that said, it shouldn't go down that quickly. If you are losing coolant quickly, you either have a leak from a loose hose or clamp, or your radiator cap is defective and is allowing the coolant to boil off. |
| Leaking coolant | dazzpowder | Engine & Drivetrain Tuning | 4 | Apr 5th, 2007 03:45 PM |
| coolant leaking everywhere | MrLee2006 | Faults & Fixes | 3 | Aug 3rd, 2006 09:48 PM |
| Are the new coolant tanks leaking? | KAMAKAZI | Faults & Fixes | 4 | Jul 8th, 2003 09:38 AM |
| Another Mini leaking coolant | visionary | Faults & Fixes | 58 | Jun 9th, 2003 05:33 AM |
| Leaking Coolant Bottle AGAIN! | daro911 | Faults & Fixes | 2 | Feb 11th, 2003 04:42 PM |
