GizzmoUSA
Old Apr 30th, 2008, 10:03 PM   #1
Maniac
Local Time: 03:24 AM
Cooper S Overheated...
I have a 2006 Cooper S. I have seen on the web they have realised there is a thermostat and electric fan fault, resulting in overheating.
My wife drives the car to work everyday, it has 30 000 kilometres on the clock, and still under BMW Motorplan.
It's in the Mini workshop at the moment. It overheated way past 120 degrees on the heat gauge, and the warning lights started flashing.
My problem, or rather question:
They are replacing the thermostat with the housing, and also the electric fan. They said they will do compression tests etc on the engine also. But how do I know if the engine is still 100%? Surely something had to get damaged inside also? Rings etc?
The dealer said they will service the vehicle, add new oil, then seal the dipstick and filler cap off. I must then drive it for about 2500km. They will then check if their is any oil consumption, if not, it's fine.
But I don't trust this. Replacing an engine after the Warranty expired is going to be a costly exercise! Want to sort it now, or get them to replace the engine and get it over and done with.
Any advice or suggestions?
South Africa   Reply With Quote
Old May 1st, 2008, 07:03 AM   #2 (permalink)
motionmonk
motionmonk's Avatar
Local Time: 09:24 PM
I have a '06 MCS as well; do you have a link to any service notice about this overheating problem?
Keep us posted on your progress!
I'm not speeding. I'm feeding my supercharger.
United States Male View motionmonk's Dark Silver & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 1st, 2008, 09:15 AM   #3 (permalink)
Maniac
No link, sorry. Well Mini at this stage did not come out in the open and confirmed this, but if you do a Google search "mini problems" you will get alot of links by the public complaining about this! Same problem as mine, and the dealers changed the same parts as mine. So mine is definitely not the FIRST car with this problem.
I'm in South Africa, Mini gave me a rental car while mine is in the workshop. When collecting the rental from the Rental Company, the guy there told me they give about 5 rentals PER day to customers, and all of their Mini's overheated also!
Will keep you guys updated
Old May 1st, 2008, 09:42 AM   #4 (permalink)
Ant FR
Local Time: 04:24 AM
my 2002 MCs did this when i bought in back 2006 . Needed a new fan assembly and loom.
I can't commetn on engine longevity as mine blew up a couple of months ago......lol
Old May 1st, 2008, 10:16 AM   #5 (permalink)
DaFlake
Dog Tired
DaFlake's Avatar
Local Time: 05:24 AM
Online
Chances of major damage being done to an engine with an overheat is minimal unless you drove it until it stopped running. That being said, there are a lot of things that can be damaged like the compressor for the AC which can be costly. I had an Escort that overheated and the engine has now done well over 150,000 miles and still running strong. I just had to have the AC serviced as it blew the coolant out.
Chances of you getting MINI to replace the engine? Never gonna happen...
Global Moderator
Old May 1st, 2008, 12:34 PM   #6 (permalink)
Maniac
Don't be so sure. I had a Isuzu bakkie. Engine was replaced the first time, when they had to replace it the second time, they gave me a new vehicle off the showroom floor as a replacement!!
Mini here is considered a luxery vehicle. It falls into the same class as Mercedez and BMW.
If I convert what we pay here for a Cooper S into US dollars, it works out at 35 000$. So customer service is topnotch when it comes to complaints here!
Old May 1st, 2008, 01:18 PM   #7 (permalink)
DaFlake
Dog Tired
DaFlake's Avatar
Online
I'm not German and I paid 32500 for mine. I just know BMW/MINI.... They will repair it. Besides, as I mentioned there is probably little damage that was done unless you drove it hard. Warped head maybe, cracked if really bad? Either way, good luck.
Global Moderator
Old May 1st, 2008, 04:09 PM   #8 (permalink)
Maniac
Wife uses the car in the week to go to work and back. It overheated in traffic, she pulled over as soon as the lights came on, and phoned me. I filled it up with water, and it was fine again. Took it to the dealer the next day.
So I don't think she damaged the engine big time.
Will let you guys know the outcome of this
Old May 1st, 2008, 06:45 PM   #9 (permalink)
DaFlake
Dog Tired
DaFlake's Avatar
Online
Good luck!
Global Moderator
Old May 7th, 2008, 07:32 PM   #10 (permalink)
Maniac
Ok, I received the MCS back today. Various tests was done on engine to ensure all is still fine. Well BMW says there is no damage on the engine, hope they are correct!
The electric fan burnt out. The fuse for the fan was also a gonnar! BMW technician told me to regularly check the fuse, as it is a problem at this stage on ALL the Mini's. For some reason they just say bye bye, and then with NO fan in traffic, it will overheat!
Thermostat housing was also leaking, that was replaced and also the thermostat was replaced....
So far so good.......
Old May 8th, 2008, 03:40 AM   #11 (permalink)
DaFlake
Dog Tired
DaFlake's Avatar
Online
Glad to hear that all is now well.
Global Moderator
Overheated MINI xx_emma_x_x Faults & Fixes 10 Sep 18th, 2006 06:46 PM
MCS overheated, no fan R3D2 Faults & Fixes 9 Aug 28th, 2006 05:46 PM
MINI overheated rica_roel Faults & Fixes 2 Apr 13th, 2005 04:35 PM
My new MINI Cooper overheated! analogbill Faults & Fixes 35 Jun 29th, 2004 10:41 PM
Overheated MCS 03 Build AussieMini Faults & Fixes 20 Apr 19th, 2004 05:02 PM
