Mighty Stripes
Old May 3rd, 2008, 04:10 PM   #1
envy
Now im Hyper!
envy's Avatar
Local Time: 11:14 PM
Problem with Battery (Cutting out on turn over)
Afternoon all, im having a bad day i tell you
Unfortunatley today, it seems my battery connetions are playing up.
I was driving down a road pulled up, to let a go pass a parked car in front of me. When i pulled away after a minute or so, the car felt like a boat! Soon realised that the Power Steering had failed!
Managed to pull up safely luckily, however i then proceeded to close the top (assuming some sort of failure was going to occur)... the roof proceeded to close and stopped half way! Then i turned the engine off, and guess what... turned over.. nothing.. absolute dead. No Temp, no starter motor, no nothing.
At this point (blocking traffic) i was pretty concerned. The boot of course was locked, as no power feed in the car. Pulled back the seats, checked connections and all seemed OK.
Now here comes a fix of sorts... i pushed on the small black box next to the POSITIVE connection. I could now hear the cars electronics booting up, and the car then started OK.
The car since has not developd any faults whilst driving. Instead if you leave the car around 30 minutes, and return.. open the car.. and then turn it over.. the same problem occurs. Again the same solution, push on the black box near the positive cable and it starts again.
I have checked the battery and it seems fully charged.. it will open/close the softop after being on for about a minute.. a dead battery would not do that?
Now im thinking of solutions/fixes for it, i would assume:
  1. Poor positive connection, may need to remove and replace the connection?
  2. This black box im pushing on, is some way faulty
  3. The loom from the back of the car to the front is faulty (but why would it start if it was faulty?)
Does anyone have any ideas? Could i disconnect the battery without having an issue with alarm resetting/Immobilser?
Thanks for any advice, its much appreciated.
Sig Coming Soon..
Old May 3rd, 2008, 04:11 PM   #2 (permalink)
envy
Now im Hyper!
envy's Avatar
Also like to add the car is a MINI Cooper Convertible S, 54 Plate, 17k Miles.. and have had no issues so far, today is the first time we have had a problem
Sig Coming Soon..
Old May 4th, 2008, 04:21 PM   #3 (permalink)
envy
Now im Hyper!
envy's Avatar
Well, its been fixed (hopefully, since had no problems).
When we bought the car they replaced the battery, and not with a BMW one. OK so not a fault as such, but the mechanic who fitted it, did not correctly place the positive connector NOR tighten the bolt holding the connector.
This was no high street garage either, this was a Volvo Stratstone Dealership in Stafford.
Therefore the connection was severed whilst driving, which of course made the power steering and then the car die. Thats also why i could start the car by pushing on the connector.
Overall a 10 minute fix BUT the idoit who installed the battery could have potentially made a dangerous accident.
Sig Coming Soon..
Old May 4th, 2008, 04:23 PM   #4 (permalink)
supa-dupa-cooper
In S Club Heaven!!
supa-dupa-cooper's Avatar
United Kingdom Female View supa-dupa-cooper's Chili Red & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Car cutting out when idling (EMS problem?) turtle Faults & Fixes 0 Mar 27th, 2007 01:42 PM
Help with battery problem! aprofetto Faults & Fixes 5 Mar 15th, 2007 12:40 AM
Engine won't start - Battery Problem? jleydon Faults & Fixes 3 Jul 11th, 2006 04:12 PM
MTH cutting out at raised rev limit ? Still a problem ? Perm Engine & Drivetrain Tuning 5 Sep 11th, 2005 06:51 PM
Problem: Changing Battery abstract Interior & Ice 2 Sep 1st, 2003 05:42 PM
