Mighty Stripes
Tags: , ,
Old May 11th, 2008, 06:45 PM   #1
Mull3t
Mini Lover
Mull3t's Avatar
Local Time: 11:01 AM
Clicking noise coming from outside car
Recently I have noticed a Clicking sound coming from the car when moving, At first I thought it maybe was a nail in my tyre or even a stone that was lodged in the tread.
Today, I decided to give my tyres a once over, I took each wheel off, and inspected to see if any signs of nails or stones.
I found a few stones that were lodged, so I removed them. I did have what looked like a small tack in 1 tyre, but it did no protrude enough to hit the ground and make the clicking noise.
(Its defo coming from outside the car, and from the drivers side, it sounds as if its from the passenger side)
After checking everything out and going for a test rest, the mystery click was still there.
My dad seems to think it MAYBE could be the Drive Cuplink? but again, we are unsure.
Its not so much of a loud click, but you know its there (as if you have something stuck in your tyre).
Anyone got any ideas? is this a common fault? expensive to repair? what else could it be? etc
I am due for my MOT in 1 month, do you think I should wait until then to see if it gets picked up? or booked it in now and fork out £'s for labour, when it could be nothing?
Old May 13th, 2008, 04:52 PM   #2 (permalink)
fordcymru
fordcymru's Avatar
Have you tried jacking up the car and spining the wheels by hand to see if you can hear and diagnose it. C.V. joints usually only click when on a full lock. Hope you find it and get it sorted because it can be very annoying.
Wales Male View fordcymru's Chili Red & Body Color 1st Gen MINI One Profile   Reply With Quote
Old May 14th, 2008, 10:54 AM   #3 (permalink)
Mull3t
Mini Lover
Mull3t's Avatar
Good idea that, I will try that tonight. I take it the CV joints will only be at the front on a Mini?
I hope its not the joints as I've heard they can be quite expensive
Old Jun 16th, 2008, 01:35 PM   #4 (permalink)
Mull3t
Mini Lover
Mull3t's Avatar
Well had the read passenger side wheel/caliper/brakes off this weekend, and when I hand span the discs, you could hear the clicking on every 1 rotate. what could this be?
Old Jun 16th, 2008, 01:42 PM   #5 (permalink)
nylo
Horse 'er on, Cynthia!
nylo's Avatar
Send a message via MSN to nylo
Is it a very tiny tick like click?
I've got one of those too, just noticed it recently
Northern Ireland Female View nylo's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 16th, 2008, 01:52 PM   #6 (permalink)
DaFlake
I miss my MINI
DaFlake's Avatar
Local Time: 06:01 AM
Synchronizer perhaps. I have always had a click on my 06 and never had a problem. My truck did this as well and it was a syncro..
Global Moderator
Old Jun 16th, 2008, 06:28 PM   #7 (permalink)
Jack678
ive got the same problem aswel. came about after i lowered my mini and painted my calipers....have i disturbed something when removing the calipers??
Scotland   Reply With Quote
Old Jun 16th, 2008, 07:09 PM   #8 (permalink)
nylo
nylo's Avatar
What's that, Will? 'Scuse the ignorance!
Old Jun 16th, 2008, 07:17 PM   #9 (permalink)
DaFlake
I miss my MINI
DaFlake's Avatar
Syncros work in the transmission to match the speed of the gear that you are going into. Without them, you would have to match the speed manually.
Global Moderator
Old Jun 16th, 2008, 07:48 PM   #10 (permalink)
nylo
nylo's Avatar
That would make sense, as I usually hear it as I'm changing gear (I think - will have to listen out for it properly now )
Old Jun 16th, 2008, 10:09 PM   #11 (permalink)
Silent1
Supercharger Noiseaholic
Silent1's Avatar
Send a message via MSN to Silent1
I was told by a friend of mine (a BMW Master Tech) that there's a known issue with runflats making odd noises, the cure is to remove them, turn them 1/4 and refit.
United Kingdom Male View Silent1's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Clicking noise!!! phil_c 2nd Gen Faults & Fixes 1 Aug 28th, 2007 07:41 PM
Clicking noise turning right Gr1zzLy Wheels, Tyres & Brakes 4 Apr 11th, 2007 10:34 PM
Loud Clicking Noise RussT Faults & Fixes 2 Apr 20th, 2006 08:57 PM
Clicking noise under load Mike Yue Faults & Fixes 3 Jul 20th, 2005 09:53 PM
clicking noise on pull away tugboat Faults & Fixes 2 Oct 3rd, 2004 06:13 PM
