Old May 16th, 2008, 05:43 PM   #1
matt21
Now with S power!
matt21's Avatar
Local Time: 12:11 AM
Send a message via MSN to matt21
Potential gearbox problem??
A friend of mine has a 52 plate Cooper (obviously pre facelift) and having some gearbox issues.
The gearbox is making a very loud noise. This increases with speed does and when under load, to the point where it is unbearable. When it is out of gear it does not make the noise at all.
The changes itself dont seem too bad its just making this horrible noise!
Any idea what it may be? Anyone had anything similar? Is it likely to be repairable? How soon may it pack up?
Questions, questions, questions....
Old May 16th, 2008, 09:55 PM   #2 (permalink)
mab01uk
Sounds like another Midland gearbox on its way out, a fairly common problem on early MINI Ones and Coopers if it is.............best get it checked out soon as some of the boxes get damaged beyond being suitable for exchanging for a reconditioned one (new Midland boxes are no longer available).
Old May 17th, 2008, 04:49 PM   #3 (permalink)
matt21
Now with S power!
matt21's Avatar
thanks
anyone else had any issues?
Old May 31st, 2008, 02:15 PM   #4 (permalink)
johnfromaus
johnfromaus's Avatar
Local Time: 09:11 AM
this is the exact problem i had. ive just finished rebuilding my box. replaced all bearings and seals and the problem is solved. is the sound hardly audible in first gear, but as you move through the gears, it gets worse. only heard when accelerating/decelerating (in gear), but dissapears when you depress the clutch, or for that split second when you let your foot off the accel and start slowing??? yes?
its a worn bearing on the output shaft. i have the little turd sitting on my desk and i swear at it every night before i go to bed and each morning when i get up. i can give you part numbers and help if you want to tackle the job.
... we are the undercompensators!
Australia   Reply With Quote
Run Flat Tire Potential Problem David Brown Wheels, Tyres & Brakes 1 Apr 14th, 2007 06:15 AM
Thule roof rack potential problem phazer Exterior 0 Sep 2nd, 2005 02:59 PM
Is this a potential problem? pob Faults & Fixes 13 Nov 24th, 2004 08:36 PM
Wollastons - Potential Ticket Problem SoggyCornFlakes MINI in the Media 5 Sep 10th, 2003 08:08 AM
Potential problem smogging SuperTrapps TonyB Engine & Drivetrain Tuning 14 Aug 19th, 2003 06:21 PM
