» Sponsors
» Sponsors
Go Back   MINI2 - MINI Forum > R50, R52 & R53 - First Generation MINI > Faults & Fixes
Faults & Fixes Got a problem with your MINI? Share it here, and maybe even find a solution
MINI2.com is the largest MINI Forum on the internet. Registered Users do not see the above ads.
Old Sep 15th, 2008, 11:42 AM
OJM's Avatar
OJM
Local Time: 01:31 PM
Spark Plug 'Metal Surround' Raised
Has anyone ever come across this before, and more importantly, do you know what has caused it etc...
When I was down at ThinkMINI approx. 1 month ago, Adrian checked my spark plugs for me. When taking out number 4, he noticed that the metal surround in the chamber was raised about 5mm. He's never come across this before, and noticed some oil around the plug as well. He cleared the oil, and gently hammered the metal back down, so it was flush with the top.
Anyway, a month on (considering my car has been in a repair shop for a month, so has probably only had 2 weeks driving in this time), and I noticed the metal has raised up again. Doing the same as Adrian, I gently knocked it back down.
Just checked today (knocked down on Sat), and it seems to still be down, but does anyone know what this is, and what problem I might have?
The BMW repair shop did mention they found yellow sludge in the radiator, so mentioned my head gasket may be on the way out (no sludge on the oil filler cap though). Could this be linked?
I've attached a pic to show the metal I'm talking about - the pic is with the HT lead pulled off the spark plug, but not all the way out.
Help!
Cheers!
Old Sep 15th, 2008, 12:14 PM
OJM's Avatar
OJM
This is the post in regards to yellow sludge;
http://www.mini2.com/forum/faults-fi...-radiator.html
Old Sep 17th, 2008, 08:10 AM
OJM's Avatar
OJM
Does anyone have any ideas? I'm wondering if the kind of yo-yo effect is being caused by this - ie, loss of pressure at that spark plug.
Old Sep 28th, 2008, 09:16 AM
OJM's Avatar
OJM
Here's a pic of it raised - not great quality, unfortunately.
Old Oct 4th, 2008, 01:55 PM
Lucky Dave
The part that has lifted is the spark plug tube.
Its not part of the plug or lead, its just there so you can access the plugs.
They are part of the head and are either pressed and or bonded into it.
Its very fixable, just remove the plug leads, intercooler and the rocker cover, then it is exposed.
It could then be removed, cleaned up and re fixed into place.
Give me a call if you need to discuss it further..........Dave
PS you wont loose pressure, the problem is if it lifts enough oil from inside the rocker cover will soak the plug top and lead.
Old Oct 4th, 2008, 04:26 PM
OJM's Avatar
OJM
Cheers Dave! When you say rocker cover...would it be best to use a new gasket when replacing it?
Do you have any pics on how the spark plug tube is connected / attached by any chance?
Old Oct 4th, 2008, 08:11 PM
Lucky Dave
I will get the camera out on Monday
Old Oct 5th, 2008, 07:50 AM
OJM's Avatar
OJM
Brilliant! Cheers Dave
Old Nov 5th, 2008, 09:37 PM
OJM's Avatar
OJM
Dave, did you manage to get any pics of how the tube is attached? Will I need a new gasket when putting the cover back on? Cheers!
Tags: , , , ,
Spark Plug Question scuderiamini Engine & Drivetrain Tuning 6 Jan 16th, 2006 03:49 AM
Spark plug help... dr remulac Engine & Drivetrain Tuning 0 Jul 5th, 2005 04:23 PM
Spark Plug E-Gun Maintenance & MINI Care 6 Feb 5th, 2005 05:57 AM
Spark plug interval zgokart Maintenance & MINI Care 3 May 25th, 2004 11:43 PM
spark plug gap ASTON Maintenance & MINI Care 5 Feb 16th, 2004 12:20 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
