» Sponsors
» Sponsors
Go Back   MINI2 - MINI Forum > R50, R52 & R53 - First Generation MINI > Faults & Fixes
Faults & Fixes Got a problem with your MINI? Share it here, and maybe even find a solution
MINI2.com is the largest MINI Forum on the internet. Registered Users do not see the above ads.
Old Jan 13th, 2009, 08:37 AM
Kryptonic's Avatar
Kryptonic
Will Johnson
Local Time: 09:06 PM
Send a message via MSN to Kryptonic
United-Kingdom Xenon Headlight broke?
Hi all,
I noticed in the last couple of days one of my xenon (passenger side) headlights has stopped working (full beam still works...) I thought that the bulb had gone, so I just rang my local dealership to get a price for a new bulb.... they quoted me £106.96 (+ vat) for one!!!!!!!!!! he said hes never heard of one "going" and i should bring it in to get looked at.... is there anything I can check myself before taking it in? can i get them cheap elsewhere (UK) ?? is it worth swapping the bulbs over to check? how easy is it to gain access to the enclosure?
many thanks!
Will
Old Jan 13th, 2009, 09:38 AM
ALD0's Avatar
ALD0
Prev Known as Interceptor
United Kingdom Male View ALD0's Hyper Blue & Black 1st Gen MINI Cooper S Profile
Yes,
Swap bulbs across first to check
If still fails
Swap the ballasts
If the bulb is at fault, a set off bulbs off other websites vary £30 upwards.
I bought a pair off 6000k off Ebay for £30 for a pair, Normally it is a case of you pay for what you get but this pair seem to be fine and have been in 3 different cars of mine.
Si
www.totalmini.com
Old Jan 13th, 2009, 09:40 AM
Kryptonic's Avatar
Kryptonic
Will Johnson
Quote: Originally Posted by ALD0 (original)
Yes,
If still fails
Swap the ballasts
Si
Hi Si,
Thanks alot mate - is it easy to remove / swap the ballasts? is there any instructions on the internet to show the process? many thanks!!
Old Jan 13th, 2009, 11:13 AM
ALD0's Avatar
ALD0
Don't recall any instructions, the first time I did it-just follow common sense, always make sure your lights/ignition is off.
From memory though:
Remove the back cover housing
You will see a Red/Black igniter, twist that gently and pull down, carefully pull out the wires connected to it at the side
Unscrew the bulb housing and gently pull down, do not touch the glass part of the bulb
The Bulb type is D2S, Facelifted MINI's 05 onwards.
It's pretty straightforward when you see start dis-assembling, just don't go in heavy handed
www.totalmini.com
Old Jan 13th, 2009, 11:19 AM
Kryptonic's Avatar
Kryptonic
Will Johnson
From memory though:
thanks mate! ill give it a pop this weekend, my mini is an R52 (2002) are the bulbs still D2S if i need new uns? cant beleive mini charging so much!!!
Old Jan 13th, 2009, 11:56 AM
jayminis
Send a message via MSN to jayminis
dont buy them from mini, i had a xenon bulb go before, just swapped the other one over to see if it had blown. it wa just the bulb so went on HIDS4U Ltd - UK's Number 1 HID Conversion Kit Specialists, they are £68 for both bulbs, its best to change both at the same time, i bought these ones below:
D2R Bulb*::*Replacement HID Bulbs*::*HIDS4U Ltd - UK's Number 1 HID Conversion Kit Specialists
they are brighter than the original, these are 6000k where as the standard ones are only around 3400k, they look so much nicer at night time. and you can see better and are still legal, had mine for over a year now and been great.
Old Jan 13th, 2009, 12:03 PM
Kryptonic's Avatar
Kryptonic
Will Johnson
thanks alot mate! ill get them ordered this week! Is it defo D2R i need for the 02 plate?
Old Jan 13th, 2009, 01:10 PM
ALD0's Avatar
ALD0
No I would check with MINI which bulb type it is for 2002. Some website will be able to tell you, btw once you know the bulb type, search around for some cheaper set than £68!
www.totalmini.com
Old Jan 13th, 2009, 02:34 PM
Kryptonic's Avatar
Kryptonic
Will Johnson
hi mate, just rung them back and they said its one of two and without seeing the bulb they couldnt tell... grrr
i guess when i get the bulb out it will say on it?
Old Jan 13th, 2009, 04:43 PM
ALD0's Avatar
ALD0
It does yeah, I would of thought their system would have it on .
www.totalmini.com
Old Jan 13th, 2009, 04:46 PM
Kryptonic's Avatar
Kryptonic
Will Johnson
hahah yeh mate, but if they told me that info they wouldnt be able to get £100 outa me!!!
I found these on ebay:
Replacement Xenon HID Bulb Rover Mini Cooper S 02- D2R on eBay, also Bulbs Lenses, Lights Lighting Accessories, Car Tuning Styling, Cars, Parts Vehicles (end time 14-Jan-09 11:04:44 GMT)
do they look like the sorta thing im after?
Old Jan 13th, 2009, 05:06 PM
ALD0's Avatar
ALD0
Yeah that would be the one, the D2R and D2s look the same but the base of the bulb is a little different.
www.totalmini.com
Old Mar 2nd, 2009, 09:46 PM
ScottyBoy's Avatar
ScottyBoy
Obsessive Car Cleaner OCC
United Kingdom Male View ScottyBoy's Solid Black & Body Color 1st Gen MINI Cooper S Profile View ScottyBoy's MINI Profile Images
Has anyone confirmed which buld it is for each car?
I.e Pre facelift and facelift.
Ive just bought a set of bulbs on ebay and bought D2S bulbs and not sure if i need D2R's my car is a pre facelift.
Scotty
Old Mar 2nd, 2009, 09:53 PM
Kryptonic's Avatar
Kryptonic
Will Johnson
mines a 52 plate and was D2R.... i thnk i saw a thread somewhere that pre facelift are all D2R. I got a set off ebay for £15 - i can give you the sellers shop if you want
  #15 (permalink)
Old Mar 2nd, 2009, 09:56 PM
ScottyBoy's Avatar
ScottyBoy
Just took the bulb out and mine is a D2R...
Typical that i aint ordered that one
xenon headlight throw Ryza Maintenance & MINI Care 12 Feb 21st, 2008 12:35 PM
Xenon Headlight Upgrade emu_p MINI Cooper 16 Jun 18th, 2007 12:10 AM
Xenon Headlight Replacement Subiklim Faults & Fixes 9 Feb 9th, 2007 12:28 AM
Headlight Washers only on the Xenon C. Crampton Exterior 3 Sep 28th, 2004 03:47 AM
Xenon Headlight Upgrade caminifan Exterior 1 May 28th, 2004 12:58 AM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
