Old Mar 1st, 2003, 03:53 PM   #1
Smudge
Smudge's Avatar
Local Time: 11:44 PM
United-Kingdom Water in Boot
Any ideas why I am getting water in the boot of new mini, the well that
holds the toolkit is a puddle of 'clean water' and the foam back of the
carpet must be holding a couple of pints.There are 2 large shaped rubber
grommets in the well, but other small holes are open. Should these have
grommets in them.
Smudge
England   Reply With Quote
Old Mar 1st, 2003, 03:58 PM   #2 (permalink)
mini_coop_her
mini_coop_her's Avatar
Send a message via Yahoo to mini_coop_her
i think there shud be grommets in them as well....fone ur dealer adn get them to look at it
Old Mar 2nd, 2003, 09:37 PM   #3 (permalink)
here2help
I have had this fault before and i found it to be comming in from the third brake light housing.This housing is made water tight by the means of a very thin/poor foam gasket which after i did various water tests was found to be sub-standard.I replaced the gasket and also made it more substantial with some butly tape.
I also have had water comming in from the rear light housings/clusters which again have foam gaskets fitted to them and are only held in by a 10mm nut and two clips...not very secure/tight to say the least.
Hope this helps!
Old Mar 4th, 2003, 07:36 PM   #4 (permalink)
MJS
MJS's Avatar
Local Time: 12:44 AM
I had this problem on my Cooper too, it went back to the dealer about 3 or 4 times. Sold it in favour of an S though
They never did get to the bottom of it....
United Kingdom View MJS's Chili Red & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Apr 24th, 2003, 02:11 AM   #5 (permalink)
Smudge
Smudge's Avatar
Sorted my boot water out. It was down to a bad bit of welding halfway up the rear pillar, open the hatch back and you can see the welded join. Min is going to body shop soon for reweld.
Old Jul 8th, 2003, 08:27 PM   #6 (permalink)
stellablade
Supposedly had my boot water problem sorted out (had seals and rear light housing replaced), but after several water free months my boot again has water under the carpet. It's only on the left hand side.
Very annoying. It's going in again next week along with my rattling drivers window, rattling seatbelt anchor, rattling doors, and rattly latch (yes I do have the electrical tape 'fix'!). Think I'll insist on them fitting the new chrome latch.
One day my MINI will be stress free
Old Jul 9th, 2003, 03:55 PM   #7 (permalink)
Smudge
Smudge's Avatar
Thought my water in the boot was solved until I went to pick up the car, when they pressure washed the back during valetting the water was getting in again. They now have the mini back to try again, and I have a BMW 1.8TI as a courtesy car so I'm quite happy. They have had the mini for 10 days now, I think they must have lost it. Still I'll keep the BMW for as long as it takes!!
Old Jul 9th, 2003, 04:13 PM   #8 (permalink)
stellablade
Whereabouts is your water problem, under the carpet, to one side? Mine is to the left of the tool box, the rest of the boot is completely dry. There isn't always that much to see, but that's because the foam carpet backing soaks most of it up.
I've had new boot seals and light housing, so that more or less rules those two out as the problem. I've been wondering if it could be to do with my boot latch rattles and the profile of the boot. The left hand side of the boot isn't quite flush with the bodywork. Turning the rubber bumpers inwards gets the boot flush, but the rattling gets worse.
Old Jul 9th, 2003, 07:39 PM   #9 (permalink)
Smudge
Smudge's Avatar
It comes in both sides Left and right. It runs out of the bottom of the side panels and onto the floor under the foam carpet, then into the tool box well.
It takes about 2-3 minutes with a light hosepipe around the edge of the door for a trickle of water to appear on both sides.
Old Jul 16th, 2003, 09:56 PM   #10 (permalink)
stellablade
Got my car back today after two days in the workshop. They're fairly confident that the water problem is fixed, we shall see!
On closer inspection I was surprised to see a vaseline like substance has been applied inbetween the light housing and the bodywork. It's very soft to the touch, so I can't see what good it will do in the long run, maybe I'll be proved wrong. The substance has a blueish tinge to it.
Aquapel to the window seals. Boot latch hasn't been upgraded to the new chrome one, but they've certainly adjusted things. Looks like they've done a decent job on the seatbelt panel rattle.
I'll give the car a good testing over the next few days.
Water in my boot! help please! MiniPetrolHead Faults & Fixes 11 Jun 27th, 2007 03:58 PM
Water in the boot solution ? Crashnet2000 Faults & Fixes 7 Nov 20th, 2006 01:17 AM
Luggage Boot - Water min106 Faults & Fixes 21 May 5th, 2006 01:41 AM
Water in Boot/Battery well B&D Faults & Fixes 6 Jul 29th, 2004 09:17 PM
Water in boot area MiniBean Faults & Fixes 11 Dec 15th, 2002 03:32 PM
