| M2 Procrastinator Join Date: Jan 2003 Location: sydney, OZ! Local Time: 11:47 AM
Offline | found this part rattling around the passenger-side footwell after a short trip home from work! i presume it dropped down from under the dash! does anybody know what it is? if not, can somebody [everybody] have a look up under there & see where it goes & what it does! cheers gary |
| MINI2 Regular Join Date: Nov 2002 Local Time: 02:47 AM
Offline | Hi Gary That's the pipe that feeds cold air from the air con unit to the glove box. If you were to take the glove box out, it is easy to see where it goes. However, that's a right pain and the pipe will drop off when you try to put the glove box back anyway. If you can, get a look in under the glove box to get a better idea of where it fits or feel around the back of it behind where the outlet is in the glovebox. To fit, slot the glove box end on first, then it should be easier to locate the other end on the air con outlet. Alternatively, if close to your dealers, get them to do it. It's one of those things that when you know how to do it, it only takes mere seconds. Hope that helps. ian |
Offline | legendary... thanks SO much for the input! it's getting late here, so i'll have a look in the morning! the dealer's not too far away, but the traffic's a real pain - i'll have a go myself first! cheers gary |
| MINI Traitor | Mate, you're screwed. That isn't for the glovebox, that is the hydraulic suspension/supercharger boost intecooler balancer tube. ![]() You see, when you're into it, the charger blows more air into the hydrolastic suspension system, firming the ride. Without that little tube, it's highly probable that all the suspension fluid could go spraying into the cabin, and you'll wear the underside of the car away as it drops into "Rice" position. ![]() Did that help ![]() Clubman less.... ![]() |
| water in Passenger footwell | Why Me | Faults & Fixes | 1 | Oct 27th, 2006 11:21 AM |
| Fuse panel in passenger footwell | abs0lutely | MINI Convertible | 1 | Aug 12th, 2004 10:17 PM |
| Passenger Footwell Squeak | wi!!iam | Faults & Fixes | 0 | Oct 31st, 2003 12:28 PM |
| Black Box on top of the passenger footwell | Jomnhta | Interior & Ice | 4 | Jul 4th, 2003 04:00 AM |
| passenger footwell Q? | Ballie | Interior & Ice | 1 | Jul 24th, 2002 09:02 PM |
