Visit Derek Woodman MINI
Old Dec 28th, 2001, 08:04 AM   #21
Paul
Trained Monkey
Paul's Avatar
Local Time: 10:36 PM
I can tell you the people at MINI are coming up with an official comment for us to post on the website. There has been some delay, but as soon as I can put this information on the site I will.
Old Dec 28th, 2001, 09:50 AM   #22 (permalink)
mr.bill
Local Time: 09:36 PM
Apial, after they fitted the new suspension parts, did they do a KDS test on it? Just curious, because if the pull is gone, the drift should be too, unless there is still an alignment problem. On the highway here, my Z (same weight and wheelbase as the MINI) tracks straight, maybe a slight drift of one foot in a hundred yards due to the road camber. If the car is properly aligned, you should be able to drive with essentially one finger. If you have to correct it constantly to keep it straight, then it is not fixed, no matter what others may say. At least it is better now, so you won't have arms like Popeye.
Old Dec 28th, 2001, 05:07 PM   #23 (permalink)
Apial
Apial's Avatar
Send a message via MSN to Apial
No the car has not been back on the KDS. The dealer says that this is not needed now as the struts fit in the already adjusted locating mounts.
Due to the strong gales it is impossible to test the steering. My gut feeling is that I need more effort to turn right than to turn left still. It does not drive as straight as my Fiat Coupe yet. But at the moment even that car is blown off the road by the wind!
Another factor is that MINI has a highly geared steering rack. You feel that the steering is in top gear compared to the 316i that I drove the other week. A little movement of the wheel produces a lot of steering action. This also makes the wheel feel heavy compared to the 316i. The power steering is not very strong. This tends to give more feed-back. There is also a lot of castor on the steering giving a strong centreing of the wheel. The problem is that my wheel feels like it is still centreing a few degrees to the left, hence the slight pull.
The repaired drivers seat failed the first time I tried to use it. Also the drivers door refused to open in cold frosty weather. I think that a linkage needs more grease.
After Xmas the dealer can fix it along with the new headlamp when it ever arrives.
Just to add to the fun, the Fiats alarm has decided to go mad. It goes off all by itself. No fault codes are shown to explain why. The battery, alternator and current drain on switch-off have all been checked. I think a new unit will have to be fitted.
United Kingdom Male View Apial's Chili Red & Body Color 1st Gen MINI One Diesel Profile   Reply With Quote
Old Dec 28th, 2001, 06:09 PM   #24 (permalink)
Basil
Local Time: 07:36 AM
Everyone else seems so focused on their own problems. Thanks Paul, look forward to some "official" feedback.
England   Reply With Quote
Old Dec 28th, 2001, 06:12 PM   #25 (permalink)
Basil
multum in parvo.........Thats a very clever and appropriate little signature Apial.
Old Dec 31st, 2001, 03:44 PM   #26 (permalink)
oxfordmini
Mr Bill,
You can't compare your Datsun in the USA to a Mini in the UK. UK roads have a lot more camber than the USA, no matter what you see on Inspector Morse. I've driven extensily on both.
Your datsun has a different type of suspension system, hasn't got PAS not to mention the drive at the other end.
As for the pull verses the drift. If the car will pull up a camber (find a empty road and drive on the wrong side) it is a problem, if it pulls right then it is just camber sensitive which is what the drift is. I hope people arn't expecting to drive with their hands off the steering wheel as that ain't going to happen.
I've driven a car (not a Mini) which was percieved to have the same problem, on a control surface, which had about half a degree of camber, it would always pull left, driving the other way it pulled right. Even if a road looks camber free it probably isn't.
Old Dec 31st, 2001, 06:43 PM   #27 (permalink)
rich
rich's Avatar
For those of us without a Classics education, what does it mean?
Australia   Reply With Quote
Old Jan 1st, 2002, 12:29 PM   #28 (permalink)
Cape Cod MINI
Exposing the Beast
Cape Cod MINI's Avatar
Local Time: 05:36 PM
I beleive the translation is something like this.
Multum: "much, greatly"
Parvo (Parvus minor minimus): "small, little"
Therefore you could translate as "much from so little", "so much from so small", "big things come in small packages", a lot for a little", etc.
Thus, the MINI fits these loose translations.
Old Jan 1st, 2002, 01:57 PM   #29 (permalink)
R1
Addicted to Speed!!
R1's Avatar
Question Testers verdict
The MINI has now been tested by most of the television motoring programs. Most of them pull no punches when giving their verdicts on the cars tested. Why haven't any of them mentioned the steering pull? Are they finding it's no different to any other cars they have tested?
United Kingdom Male View R1's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 1st, 2002, 02:07 PM   #30 (permalink)
BruceK
Moderator & Sponsor
BruceK's Avatar
Local Time: 03:36 PM
Re: Testers verdict
That’s a good question. I would bet that before BMW releases any MINI to the press, it is well sorted out and any obvious flaws are corrected or another, fault free car is substituted.
Sorry to appear cynical, but I'm sure it is done that way.
Old Jan 1st, 2002, 02:16 PM   #31 (permalink)
R1
Addicted to Speed!!
R1's Avatar
Re: Re: Testers verdict
Good point, but a lot of the cars tested were "Y" reg and BMW doesn't seem to have a fix for the pull / drift acording to some of the posts on here!
Old Jan 1st, 2002, 03:47 PM   #32 (permalink)
LMB
Toon Toon..
LMB's Avatar
<div><a href=
Red face Hum
I read somewhere a while back that due to the Mini's design BMW weren't going to make that much money on each Mini sold. With that in mind I don't believe for one second that BMW don't have a fix for the 'Pulling to the left' syndrome. But rather they don't have one that is economically viable.
LMB
Global Moderator
England Male View LMB's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 1st, 2002, 06:24 PM   #33 (permalink)
Basil
Re: Hum
LMB
If it was a "design" problem, ALL MINI's would have the "pull". Move the factory to Germany. That will fix it.
Apologise to insiderMINI
Old Jan 1st, 2002, 06:30 PM   #34 (permalink)
Basil
I have to agree BruceK. These problems just have to be the way the cars are being put together. Cars built on Tuesday's or Wednesdays are probably the ones to get.
The older I am the more cynical I become, because less of the written word is the truth......
Old Jan 1st, 2002, 06:55 PM   #35 (permalink)
ricardo
Re: Testers verdict
...I would bet that before BMW releases any MINI to the press, it is well sorted out and any obvious flaws are corrected or another, fault free car is substituted....
Back in the summer, Car magazine got hold of a Cooper pre-launch (much to BMW's annoyance). This had not been prepared as a press car. Car complained of understeer (which was not present in subsequent MINIs they tested) but no problem with a pull to the left.
It's hard to reconcile this drifting/pulling problem with the car praised so highly for its handling by Car, Autocar and Auto Express testers. Clearly there's a percentage of rogue examples out there which behave totally differently to the cars they tested.
The official explanation/statement will make interesting reading - let's hope it is explicit about what has caused the problem and how it has been eradicated.
United Kingdom View ricardo's Chili Red & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Jan 1st, 2002, 08:56 PM   #36 (permalink)
rich
rich's Avatar
To: The creators of this forum
Are you MINI2 guys (i.e. Paul Mullett et al) in touch with BMW regarding this issue either formally or informally? Can you press them for a response that can be quoted on this forum?
If BMW will not respond directly to this forum, do you have any contacts in the motoring press that could lobby BMW for a straight answer?
If BMW actually spoke on the subject, maybe all us Mini enthusiasts could get on with talking about something more positive & interesting in this forum. After all, that would be in BMW's interests
I'm not bored with this subject & I don't want it hushed up because it's negative about our beloved car... I just want some bloody answers so we can all move on
Old Jan 1st, 2002, 09:03 PM   #37 (permalink)
LMB
Toon Toon..
LMB's Avatar
<div><a href=
Re: To: The creators of this forum
Don't we all
LMB
Global Moderator
Old Jan 1st, 2002, 09:04 PM   #38 (permalink)
Basil
Paul has contacted BMW Rich.....still waiting
Old Jan 4th, 2002, 12:51 PM   #39 (permalink)
oxfordmini
It won't make any difference as the parts would still be supplied by the same company, it isn't an Oxford assembly issue.
All press cars are built to optinum tolerances so are, for want of a better word, perfect. BMW is unlike other manufacturers who fiddle the cars, i.e fit better engines, stiffer suspension etc. I think it was CAR magazine who recently commented on the fact they believed Skoda had fitted a 225bhp engine insted of the 190bhp in a Octavia RSi they had for testing. (a follow up car was much slower)
Old Jan 4th, 2002, 04:40 PM   #40 (permalink)
Paul
Trained Monkey
Paul's Avatar
I have been in touch with MINI UK, several times, about this and they have in turn been in touch with Munich and the USA etc..
I have requested on all our visitors behalf for an official statement, specifically on the pulling to the left issue. The right people do read this site, and do take note... but this feedback is taking a very long time.
What with the xmas and new year break I was not expecting anything this week, but I would hope very much so to have a reply next week, as this isn't going to go away if you ask me.
Can a MCS do drifting on a hairpin road? missMuffin General Discussion 24 May 10th, 2007 03:18 AM
Boost Mods ... for drifting :) Cobra_S General Discussion 18 Jul 3rd, 2004 07:14 AM
Seems to judder when pulling away Mega Mini Faults & Fixes 20 Jan 3rd, 2004 06:15 PM
Pulling to the left?? paultrfc MINI Cooper S 11 Nov 9th, 2003 08:39 AM
Is Yours Drifting? Steeljacket MINI Cooper S 4 Oct 8th, 2003 03:58 PM
