| MINI2 Newbie Join Date: Jun 2003 Location: Berkshire Local Time: 10:37 AM
Offline | Sunroof rattles and its driving me nuts !! Has anyone else out there had a problem with the sunroof rattling, my mini has been to the dealer twice for this problem, they tried the usual stuff putting some grease on the runners, and tightening the mechanism, still it rattles just as bad if not worse - it happens on tilt or when its fully open. The only option left is for a new sunroof to be installed, don't really want that cos' I've heard that it could start leaking, anyone out there whose had the same and got a fix |
| MINI2 Regular Join Date: May 2003 Location: Atlanta, GA Local Time: 10:37 AM
Offline | Yep when your roof is open, look at the two flaps that are in the up position, you should notice wear places where the retractable roof has been rubbing, put some small velcro pads, this is what is causing the raddel and making the sound, the two plastic flaps move aganist the window when closed, use the wear spots to determine where to put the padding. this should fix it, you may have to adjust a little to you get the postion correct. Hope this helps DMonk |
| Minis Are Zippy Join Date: Oct 2001 Location: Bristol UK Local Time: 10:37 AM
Offline | If you search the Faults and fixes forum for sunroof, it will pull up the relevent threads for the velcro spot soln. My mini is going in next week to have the sunroof rattle fixed. They might replace the cassette - so I hope it will not leak. |
Offline | Well thanks for the input, have also checked the fault/fixes forum, after a couple of tweeks and a test drive last night still as bad, sunroof now grating when closing, the noise seems to be coming from the back supporting brackets, looks like I'll be back at the dealer this weekend, maybe I will end up with a new cassette/mechanism too. After the amount of times I've been in for sqeaks, rattles and recalls which haven't been done properly, they all run for cover when I appear in service reception, and don't even have to ask the reg. number they just know !! Maz if your dealer replaces the cassette can you update this thread with the results, after a good downpour of course - cheers |
| | #7 (permalink) |
| MINI2 Regular Join Date: Jan 2003 Location: UK/Luxembourg Local Time: 11:37 AM
Offline | Mine rattles too when fully open. If anyone knows what the fix is for this, I would be very grateful. Putting velcro on the flaps doesn't help, as the sound is coming from the back of the opening, not the front. I also notice that when the roof closes, it makes a 'clack!' sound on one side, which it never used to do. I can't find the cause of either of these problems! 2002 Mini Cooper 1979 Ford Mustang 2.3 Ghia BRG Cooper with white roof, 16"alloys, auto a/c, sunroof, seat heaters, sport suspension, shorty aerial |
| | #8 (permalink) |
| MINI2 Newbie Join Date: May 2003 Location: Carlisle Local Time: 11:37 AM
Offline | we`ve had a new cassette put in ours and it rattled and creaked still. Its been back again for 'adjustment and lubrication' and the noises have stopped , but for how long?........... Apparantly, our dealer is contacting MINI UK for advice,....is that a pig flying past my window? My advice, dont give up on the problem Silver/Black Carlisle Cooper.....Stop Drooling!! |
| | #9 (permalink) |
| MINI2 Regular Join Date: Jan 2003 Location: london Local Time: 10:37 AM
Offline | i have noticed the sunroof rattles more when its hot outside. the mini sunroof is the worst i have come across, wish i got aircon instead sometimes.sounds like going to the dealer is a complete waste of time so i'm gonna tackle it myself. my plan is to grease every screw and washer and every support point. wish me luck. if i dont succeed i'm gonna weld the damn thing shut! knowledge is power |
| | #10 (permalink) |
Offline | Back down William Jacks (Sunningdale) on Saturday morning, Sharon (very helpful) in Service reception has agreed all of my problems have gone on too long and its unacceptable, so have decided to go for a complete new sunroof to be fitted, I've been assured it won't rattle any more or develop any leaks - lets wait and see, they've even agreed to replace my scratched seat backs - hopefully it will be OK and be a happy Mini owner once more Last edited by Sarndee : Jul 2nd, 2003 at 05:55 PM. |
| | #11 (permalink) |
| MINI2 Senior Join Date: Jul 2002 Location: Virginia Beach, VA Local Time: 06:37 AM
Offline | If your sunroof scrapes or squeals when opening or closing and rattles when open, try the procedure I did on mine: http://www.type2.com/bartnik/mini_sunroof.html I did this several months ago and the squealing and rattling have not returned. |
| | #12 (permalink) |
Offline | And I thought it was just myself going mad, when I said to the dealer, its worse when its hot. Keep at the dealer.....ours tried to reassure us by saying "we get 60K cars in here with similar problems", my answer to that little ditty was "I dont care if the MINI cost £100, I want the bloody thing to work correctly"!! Silver/Black Carlisle Cooper.....Stop Drooling!! |
| | #13 (permalink) |
Offline | Tried Sean's fix and its worked, thankyou, thankyou, thankyou !! I am so pleased, gonna cancel my new sunroof, so at the mo' I have a rattle free MINI, long may it continue |
| | #14 (permalink) |
Offline | Finnaly got my MINI back last nite. The dealer has fitted a new cassette. Went for a good blast and positioned the sunroof in all its various positions. I am glad to report no squeeks or rattles - yet! Will have to wait until it rains to check for leaks - being in the UK shouln't be too long. |
| | #15 (permalink) |
Offline | Thanks for the update Maz, glad yours is OK again, mine is still rattle free since trying Sean's fix, looks like our babies were in dock together got mine back last night too after having new seat backs installed. I've passed the sunroof fix onto the dealer for any other MINI owners with problems they were very grateful for advise "its new technology you see" eh , anyway hope you continue to stay rattle free and dry |
| | #18 (permalink) |
| MINI2 Regular Join Date: Jan 2003 Location: Hamilton Local Time: 05:37 AM
Offline | Same problem I just picked up my car from the dealer after having the steering column replaced, and getting the sunroof fixed for the exact same problem you mention. They said that they had to drop the headliner, and adjust the cassette (?), and that will cure the problem. It's raining today, so I haven't had the opportunity to try it out for real, but if it does come back, I'll be trying Seans fix. Incidentally, I also had a really good 'crack' noise whenever I opened the roof past the 'popped' position, and the problem seemed worse when it was hot out, or at least had the sun baking on the roof. I still need to cure the cold weather rattle that comes from the wind deflectors, but at least I know the cure for that one, and can deal with it myself. Steve 2002 Pure Silver and Black Cooper |
| | #19 (permalink) |
Offline | The link Oh yeah, and I tracked down the new link to the fix. http://mini.uglydoris.com/archives/000026.html Steve 2002 Pure Silver and Black Cooper |
| | #20 (permalink) |
| MINI2 Newbie Join Date: Mar 2003 Local Time: 10:37 AM
Offline | Mine dealer told me mine rattled and has order a special tool to fix it. He also went on to tell me they have ordered a new parcel shelf. They were replacing the upper and lower steering rack and stopping the boot latch sounding like a machine gun which they did but was please they mentioned some stuff I had not noticed |
| Vibration Driving me nuts!!! | super c00per | Interior & Ice | 8 | May 17th, 2007 10:22 PM |
| sunroof tilted during fast driving not good??? | mini_macky | Faults & Fixes | 5 | Sep 21st, 2005 03:52 AM |
| This is driving me nuts! | Nick-o | Interior & Ice | 2 | Aug 31st, 2004 02:04 PM |
| Rattling driving me nuts!!!! | Tigger | Faults & Fixes | 8 | Aug 26th, 2003 06:33 PM |
| The boot is driving me nuts | Lorien | Faults & Fixes | 5 | Jun 11th, 2002 12:28 PM |
