» Sponsors
» Sponsors
Go Back   MINI2 - MINI Forum > R50, R52 & R53 - First Generation MINI > Faults & Fixes
Faults & Fixes Got a problem with your MINI? Share it here, and maybe even find a solution
MINI2.com is the largest MINI Forum on the internet. Registered Users do not see the above ads.
Old Jul 14th, 2003, 07:29 PM
Matg28's Avatar
Matg28
total mini dot com!!!
Local Time: 12:35 PM
Question Dashboard Trickery.....
Thought I would try out an old trick for the 3-series BMW (E36) on my mini...
Hold down the Trip Reset button, and move the key to position 1.
This brings up the Test menu system - push the trip-reset to move to the next available test. (Test 2 is a good one!!)
To unlock the other tests, select test 19, wait for L_off to appear, and hit the trip-reset. Trip 0 will now appear.
Haven't got a clue what most of the info is for, but it looks like there's the build-date of the vehicle, the current date/time etc etc.
If anyone has any more info on this, please share !
Old Jul 14th, 2003, 07:51 PM
Bonjour's Avatar
Bonjour
der Hummermeister
United Kingdom View Bonjour's Solid Black & White 1st Gen MINI Cooper Profile
What's test 2? I might give it a go when I finish work...
Old Jul 14th, 2003, 11:23 PM
MiniMan7's Avatar
MiniMan7
Let's Motor.
Local Time: 08:35 AM
Send a message via MSN to MiniMan7
Canada View MiniMan7's Electric Blue & White 1st Gen MINI Cooper S Profile
Let us know if anything is found, I would be very interested to find out.
Adam
Old Jul 14th, 2003, 11:24 PM
Bonjour's Avatar
Bonjour
der Hummermeister
Test 2 checked that all the lights, gages etc worked on the dash. I suppose it was pretty cool seeing the tach go all the way to the top.
Old Jul 15th, 2003, 01:40 AM
MiniMan7's Avatar
MiniMan7
Let's Motor.
Here it is, I found it in a search.
Test 1 - Vehicle Specific Data
1.0 319XX Last 5 of VIN
1.1 46463 Body Number
1.2 0 691872 BMW Part Number of cluster 6211-6918720
1.3 058712 Coding Index 05 / Diagnostic Index 87 / Bus
Index 12
1.4 0702 Manufacturing Date (Calendar Week / Year)
1.5 1 05_150 Cluster Hardware 05 Cluster Software 15
AI Level 01 (ai level is a guess)
1.6 _ _ _ 0 _ _ Don’t Know. Any Ideas?
1.7 07_ _ 10 CAN Index 07 Modification Index 10
(Just a guess based on the cluster label.
Yes I removed the cluster)
Test 2 – Cluster System Test
2.0 Sequential test of all gauges indicators and LED
segments. Kind of funky to watch.
Test 3 – Don’t know. I think it has something to do
with service intervals
3.0 _ _ 0785 This seems to increase as I drive.
_ _ 0051 ??
Test 4 – Momentary fuel consumption
4.0 _ _ _ 061 6.1 L/100 Km
4.1 _ _ _ _ 48 4.8 L/Hour
Test 5 - Distance Gone Consumption
5.0 _ _ _ 082 8.2 L / 100 Km
5.1 _ _ _ 351 351 Km to empty?
Test 6 – Fuel Level. These all seem to have
something to do with the fuel level as
far as I can tell.
6.0 142113 Both the third and sixth digits varied
at a stand still so I think there are two
separate readings packed in here.
Are there two fuel sensors?
Are there two tanks? 14.2 L & 11.3 L?
6.1 _ _ _ 260 Again, varies with fuel level.
26 L total?
6.1 1_ _ _ 270 In the BMW E46 the 1 indicates
both sensors are okay. 2 Indicates
1 sensor fault.
Test 7 – Temperature and Speed
7.0 _ _ _ 087 Coolant Temperature
7.1 _ _ _ 025 Outside Temperature
7.2 XXXX Engine RPM
7.3 _ _ _ 099 Vehicle Speed KPH
Test 8 – Hex Code Cluster Inputs/Outputs? 8.0 – 8.3
Test 9 – Battery and Charging system.
9.0 13.8 Battery Voltage
9.1 - - - - - - No idea!
9.2 - - - - - - No idea!
9.3 - - - - - - No idea!
Test 10 - No Idea
10.0 - - - - - -
10.1 - - - - - -
10.2 5 691872
10.3 028612
10.4 _ _ 0702
10.5 004 _ 090
10.6 - - - - - -
10.7 07 _ _ 07
Test 11 -
11.0 _ _ _ _ _ 7
11.1 000000
Test 12 – Does not exists
Test 13 – Gong Test
13.0 Sounds the cluster gong
Test 14 - ?
14.0 672000
14.1 000000
14.2 000000
14.3 000000
14.4 000000
Test 15 – Bit maps of some vehicle options/switches
inputs? Outputs?
Test 19 – Test Function Lock/Unlock
19.1 The display will change from ‘L-on’ to ‘L-off’
very second. To unlock all of the test functions
press the trip reset button as soon as you see
the ‘L-off’
Test 21 - Reset
21.1 Reset the cluster software
rattle under dashboard tendons Faults & Fixes 19 Yesterday 01:55 PM
Carbon Dashboard KMK163 Interior & Ice 19 Mar 12th, 2008 11:45 AM
05 Dashboard johnny_g Faults & Fixes 0 Sep 24th, 2006 08:50 PM
IAT electronic trickery? BluMiniMe Engine & Drivetrain Tuning 11 Jun 23rd, 2004 01:26 PM
how to remove the dashboard.... boblbee Interior & Ice 10 Sep 11th, 2003 01:46 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
