Old Jul 15th, 2003, 02:09 AM   #1
paprika
Local Time: 01:47 AM
CVT lunging from 1st to 2nd
When driving my 2003 MC in Manual Shift mode, I get a very strong lurching or lunging when shifting from 1st to 2nd at high RPM.
Is this normal or another of the Mini transmission problems (which might be sorted out with a software upgrade) ?
Canada   Reply With Quote
Old Jul 15th, 2003, 04:24 AM   #2 (permalink)
Sejanus
Moderator
Sejanus's Avatar
Local Time: 06:47 PM
I've never come across that problem myself.
United States Male View Sejanus's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 15th, 2003, 04:38 AM   #3 (permalink)
nfo
Local Time: 08:47 PM
i got the same thing!
i'm taking in the car on wed to have it checked out, i'll let you know what i find out!
Old Jul 15th, 2003, 02:11 PM   #4 (permalink)
cooper4us
cooper4us's Avatar
Get software update 33.2. All lurching symptoms has dissapeared ever since the update was done 3K miles ago. As a matter of fact my transmission lurching went away after software update 32.1
'02 MINI Cooper CVT
United States View cooper4us's Pepper White & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 15th, 2003, 11:19 PM   #5 (permalink)
paprika
Dealer honesty...
How can I "force" the dealer into doing this if he disagrees and how can I then confirm that it was done. Can they provide some sort of printout or something or do I take their word for it?
Old Jul 15th, 2003, 11:55 PM   #6 (permalink)
nonsequitur
Moderator
I think you should be able to believe the dealer's answer to your direct question about the software version in your car.
I quickly checked our service receipts finding that there is no standard notation for software version (like Mileage In or Mileage Out) on the BMW-approved documents, but each change was noted on the receipt for that day. When asked, I been given the correct answer each time.
As this software continues to be worked and new versions released by MINI, it's important to note that they are not in the business of just upgrading to the latest iteration. The idea is to resolve identified problems like the lurching described.
I wish a web-based "Support Center" were part of the Owner's Lounge where we could simply self-diagnose some of these questions. It could be twisted into good marketing for MINI. I've never seen a list of the software versions and what they are supposed to do.
'02 MINI Cooper CVT (prod. date: 6/12/2002; Indi Blue/Black roof, R-81 7-hole 15x5.5" or NZO 16x6.5")
'67 Austin Cooper S 1275 Mk1 (build date: 6/26/1967; Tartan Red/Black Roof, Minilite 10x4.5" or 10x6.0")
United States View nonsequitur's Indi Blue & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 16th, 2003, 12:01 AM   #7 (permalink)
BartMack
#1647 of 1960
BartMack's Avatar
Local Time: 09:47 PM
Send a message via AIM to BartMack Send a message via Yahoo to BartMack
I have a theory on the 1-2 steptronic shift thing....
(this really only applies under full force acceleration)
I think it is triggered by an 'ease up' of the accelerator just prior to shift. I find that if I am careful not to ease the accelerator before the 1-2 shift I get a smooth transition. If I let up on the gas just before I pull the shifter, (under hard accel) I do get a jerky 1-2 shift.
If I stick to the gas, I get a smooth shift.
Old Jul 16th, 2003, 12:19 AM   #8 (permalink)
nonsequitur
Moderator
BartMack may have hit a good one here.
The electronic throttle establishes a "target speed" in the EMS2000 computer map for acceleration. Moving the pedal re-establishes this map creating changes in behavior, which may not be what you want. Finding a correct pedal position and holding it steady there seems to be an important Cooper CVT driving skill.
It is true that lifting slightly as you would for a manual transmission gear change is not needed, and not desired, for the CVT.
Old Jul 16th, 2003, 07:02 AM   #9 (permalink)
Sejanus
Moderator
Sejanus's Avatar
Good point. I've also found that the gear shifts in steptronic mode are much smoother if you keep a steady position on the gas pedal.
Old Jul 16th, 2003, 11:43 PM   #10 (permalink)
nfo
i got my software updated today, i'm very happy to say the least! all the lurching symptoms have gone bye bye!
woot!
Old Jul 17th, 2003, 12:03 AM   #11 (permalink)
nonsequitur
Moderator
This would indicate that CD#34.0 must do something good for the Cooper CVT. Thanks for the followup, nfo. What did your service advisor say about the new software?
Old Jul 17th, 2003, 12:32 AM   #12 (permalink)
cooper4us
cooper4us's Avatar
Wait a minute....is that 33.3 or 34.0??
'02 MINI Cooper CVT
Old Jul 17th, 2003, 01:09 AM   #13 (permalink)
nfo
they told me that they just got this new software at the start of the week, so i'd assume it's #34...hmmm.
Old Jul 17th, 2003, 03:30 AM   #14 (permalink)
nonsequitur
Moderator
Our dealer used the term "34" (not "34.0" which has been typical in this casual BMW naming game). After they gave up whole number jumps (at "30" I think), the x.1 or x.2 idea showed up for interim versions. I'll try to check here again, but they said "34".
1st - 2nd crunch Dom Faults & Fixes 27 Dec 1st, 2006 02:51 AM
1st Gear to 2nd? Jonny H Faults & Fixes 5 Nov 9th, 2006 01:50 PM
hard to get 1st and 2nd gear Richy777 Engine & Drivetrain Tuning 1 Mar 26th, 2006 06:06 AM
1st to 2nd clunky shifting ciaranob Faults & Fixes 10 Feb 15th, 2004 07:23 AM
Noise shifting from 1st to 2nd grafiksguy Faults & Fixes 5 Aug 4th, 2003 01:36 AM
