Visit Lohen!
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 6 votes, 5.00 average.
Old Sep 11th, 2003, 09:44 AM   #1
pob
pob's Avatar
Local Time: 10:57 PM
HELP NEEDED - Do I reject?
Picked my replacement Cooper up on 1 Sep, and there are a few niggling things wrong with it. Main concern though was a haziness in the paintwork and a scuff near the n/s/f headlight, from the bottom corner to the radiator grille. I've been to the dealer this morning for them to look at it and they've said it's a paint defect, and they also spotted a crease in the bonnet which they say is a manufacturing defect. They initially offered to repair by respraying the affected area, which I turned down. They then said they would replace the bonnet, but I'm worried about colour matching and what it might look like in a few years time. My only other option is to reject the car - any advice would be much appreciated!
United Kingdom View pob's Pepper White & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Sep 11th, 2003, 10:05 AM   #2 (permalink)
Paul
Trained Monkey
Paul's Avatar
I would get things on paper first of all, and I would let them replace it ONLY the basis and understanding that if you're not happy with it after that, then you will reject it.
That way, you give them a fair chance, and you could have a perfectly good replacement bonnet and everyone's happy, but if you're not happy, you've already said you will not accept the car if you are not happy with the repair, so you cant be caught out by being deemed to have 'accepted it'.
Seems fair on everyone that way.
Old Sep 11th, 2003, 10:08 AM   #3 (permalink)
Old School Jonnie
Old School Jonnie's Avatar
Hi Pob!
I would reject the car immediately.
I had similar problems when my dealership drilled the roof rack mounts in the wrong place. They offered to repair and respray the roof. Like yourself i was concerned re colour match and also that they know about the repairs, would this effect the reslae/trade in value???
Legally, if you've reported the fault within a month of purchaser you have not yet legally accepted the vehicle, you have a right to reject.
Stand your ground, there's a lot of rubbish told about customer rights and cars but you have the same rights as with any other goods purchased.
I have rejected 2 MINIs in the last 14 months. Any problems - get a letter from your solicitor - this will do the trick.
Good Luck
Hyper Blue/Black Cooper. Side skirts/Aero grill, Milltek, chrome bitz and a scary roof graphic.
A SKATEBOARD IS FOR LIFE NOT JUST FOR CHRISTMAS
United Kingdom View Old School Jonnie's Indi Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 11th, 2003, 10:23 AM   #4 (permalink)
Paul
Trained Monkey
Paul's Avatar
Quote: Originally Posted by Old School Jonnie
Hi Pob!
Good Luck
I've rejected two cars (well, one older MINI "bought back" and a newer one exchanged at no cost), I wouldn't reject it straight off, it's a bit different to a misplaced hole in the roof (or a set of them), a bonnet is an easily replaced part, a roof is a WHOLE other issue.
Old Sep 11th, 2003, 10:53 AM   #5 (permalink)
pob
pob's Avatar
Cheers for the advice. I've told them I'll sleep on it and tell them tomorrow. My concern with the bonnet is what happens a few years down the line? It may look right now, but you see plenty of cars on the road with new panels which over time don't match the rest of the car.
Old Sep 11th, 2003, 11:18 AM   #6 (permalink)
Martin L
MINI defector
Martin L's Avatar
As your dealer will do the work, it will be guaranteed like the rest of the bodywork. So if it does "fade" in a few years faster then the rest they should be able to redo it under the guarantee
This is exactly the reason why any repair work should be done at a MINI approved workshop
MINI, RX8 and MX5 - Done those............. It's now TTime
Unofficial MINI2.com bean counter
England Male View Martin L's Astro Black & Body Color 2nd Gen MINI Cooper Profile   Reply With Quote
Old Sep 11th, 2003, 12:15 PM   #7 (permalink)
ideaexchange
Local Time: 05:57 PM
Canada
I received delivery of my new MINI Cooper on a Friday...
On Monday the engine light came on.
Tuesday the dealer told me it was a vacuum problem and they would fix it Thursday.
Thursday it turns out it is a wire sling which will be delivered Monday.
Monday they replace the wire sling and the central computer fails.(shorting out apparently)
Tuesday they replace the computer and the car is running fine ? but now it won?t start properly
I finally got my car back yesterday. After 10 minutes on the road the engine light came back on, the EMS light lit up and the engine lost power.
Needless to say its back at the dealers. They now tell me there is an error reading indicating incorrect gas/air mix.
Do you think I should reject this car?
Old Sep 12th, 2003, 10:12 AM   #8 (permalink)
pob
pob's Avatar
I probably would try to!
Old Oct 10th, 2003, 11:44 AM   #9 (permalink)
pob
pob's Avatar
Car has now covered 160 miles and list of problems has grown. I now have a list of 12 faults:
refelctor missing on near side door
reverse light poorly fitted
creak from steering column
rear number plat not centred properly
clutch pedal rubber falling off when delivered
paint defect on bonnet by near side headlight
crease on bonnet
rattle from o/s front windo
rattle from n/s door
hestitation at 2000rpm
leading edge of n/s door not flush with wing
difficulty selecting 1st and 3rd gears
The car is a disatser area. It's in with the dealer at the moment to fix all these issues on the understanding that this is their one and only chance before it gets rejected.
I've defended MINIs in the past but this is ridiculous. Suffice to say MINI customer services are also involved. I wish I hadn't got rid of my old Cooper - at least the problems with that one were minor. After the experience with this one I honestly can't recommend MINIs to anybody any more.
When to reject and when not to reject your car!!! Dazmac13 2nd Gen Faults & Fixes 36 Sep 1st, 2008 11:34 AM
Should I reject it? BERT R56 2nd Gen Faults & Fixes 5 Mar 24th, 2007 10:03 AM
REJECT - success KAS_COOPER Faults & Fixes 10 Jan 8th, 2003 01:48 PM
Am I in a position to reject yet? Buzzzzzz Faults & Fixes 7 May 27th, 2002 05:33 PM
Should I REJECT it. blade929 Faults & Fixes 19 Jan 3rd, 2002 04:09 PM
