| MINI2 Newbie Join Date: Sep 2003 Local Time: 08:35 PM
Offline | Vibrating air pipe on lefthand side of engine cover My MCS has developed a vibration within an air pipe connected to the top lefthand side of engine! Has anyone else had this fault or knows what it could be? cheers steve |
Offline | engine breather hose Just an update on vibration noise! I've sourced the noise to a breather hose connected to the leftside of rocker cover. Hose has a 90 degree bend which has closed-up blocking airflow. New hose required! Has anyone else had this fault? Rgds Steve |
| | #6 (permalink) |
| Man Of All Mods | The hose should be replaced under warrenty. Not only does the noise come from the hose itself but i know of a problem where i has been the oil breather valve. If you listen carfully, then you will be bale to hear a slight ( ticking ) noise. The only way i can describe it. This part is also usually changed. I had mine changed and the nose stopped. Just speak to the dealer and they should sort you out. Hope this helps |
| | #7 (permalink) |
| MINI2 Regular Join Date: Jul 2002 Location: Boston, MA Local Time: 04:35 PM
Offline | I have a strange high pitched ringing noise at certain RPM's. Could someone take a digital photo of the suspect hose and post? thanks! Mark EB/W May '03 MCS, v.36 stumble buster software (previously v. 33.2) EX-STUMBLER - Still YO-Yo-ing |
| Damage to air box cover. | Freon Warrior | Engine & Drivetrain Tuning | 21 | Mar 10th, 2008 10:46 PM |
| Chrome exhaust pipe cover | dundeered | 2nd Gen Exterior | 4 | Sep 30th, 2007 03:08 PM |
| Rear Seat catches replaced + engine breather pipe missing! | davep | Faults & Fixes | 4 | May 17th, 2004 12:09 PM |
| Looking for side-door cover | acor | Interior & Ice | 0 | Apr 6th, 2004 03:46 PM |
| Need a new air box cover, where from?? | Robm_lufc | Engine & Drivetrain Tuning | 8 | Apr 1st, 2003 11:54 AM |
