Visit Derek Woodman MINI
Old Sep 30th, 2003, 10:35 AM   #1
sgrewal
Local Time: 08:18 PM
England Rear wheel noise?
Has anyone experienced a metallic / whining noise which is worse either from start up a hill or reversing back / pulling away in first. Appears to come from the rear wheels - almost as if some parts are rubbing - (similar to having handbrake on slightly - PS I have checked that it is not on...) The noise gets worse once the car is warm - i.e. after half an hour driving or so!
The worst thing is my commut everyday consist of a very steep hill in St Albans......
Sukhjit- MINI NOW GONE - did have a 2002 MCS - Dark Silver / Black with Chili pack
Old Sep 30th, 2003, 12:38 PM   #2 (permalink)
minitech
Let's Motor...
minitech's Avatar
Local Time: 03:18 PM
Send a message via MSN to minitech
if the wheel has been off in the past the dust sheild could be slightly bent and rubing against the rotor. the other problem could be the caliper is failing and keeping some pressure on the rotor. it is normal for the pads to slightly drag against the rotor but if you were to lift the car and spin the wheels they should spin almost freely. the front wheels will have more drag than the rear due to the added drivetrain componets.
let's motor
Wheel Noise after Kerbing Adrian_T Wheels, Tyres & Brakes 4 Mar 16th, 2007 04:52 PM
Noise at back wheel MiniBimmer Faults & Fixes 5 May 30th, 2006 11:15 AM
Steering wheel noise Geoff & Gill MINI Convertible 3 Nov 22nd, 2005 06:19 PM
noise noise and more noise (wheel bearings?) eddie_DV52_CCZ Faults & Fixes 2 May 22nd, 2004 11:28 AM
Steering wheel noise, please help. Southernsun Faults & Fixes 4 Feb 12th, 2003 07:08 PM
