Old Oct 29th, 2003, 06:48 PM   #1
TJMathias
Local Time: 11:21 PM
Help-My car is seriously broken!
Ok, installing new amp today (although i dont think this has anything to do with my problem). I left my headunit on for a little too long, with the heater and so on , and the battery i think ran itself down. However, before i got another car to jump start it, i gave it another go, and it started first time!
However!
-My right indicator is atleast twice the speed of the left one
-The boot wont lock and shut properly.
-Rear window wiper wont work (although it still washes n wipes together)
Any advice?
Nice one
Old Oct 29th, 2003, 07:58 PM   #2 (permalink)
IBMiniG
IBMiniG's Avatar
Local Time: 04:21 PM
Back when I used to install stereos, I has a car that when done with the new system, the windshield wipers were on when the key was in the ignition, take the key out they would turn off. Finally I found a screw I used to hold a wire clip, went through the sheet metal and into a wire loom on the other side where I anchored my wire. I could only see the wire loom when I removed the offending screw, took a LONG time to find the problem. Sounds like the is a short with wires going to the rear of the car, check all your screws, just an idea.......
WARNING-Objects in rear view mirror have a tendency to disappear!
9/20 build '03 MCS IB/W/W, everything but the NAV & Sunroof
Old Oct 29th, 2003, 08:13 PM   #3 (permalink)
TJMathias
hmmmm, only used one screw today!
will have a grand ol look tomoro, but its a bit worrying coz the symptoms of the problem are not nice.
Nice one for the input.
Old Oct 29th, 2003, 08:17 PM   #4 (permalink)
Nameless
Nameless's Avatar
Local Time: 12:21 AM
I take it you've checked all the fuses?
( Sorry for stating the obvious )
United Kingdom View Nameless's Velvet Red & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 29th, 2003, 08:20 PM   #5 (permalink)
TJMathias
im no genius, so i will go n check all my fuses!
However, is there a fuse for the rear boot latch only? And if a fuse has gone, how come the rear wiper only works half the time, as opposed to not at all. Lastly, why would it speed up my indicator on the right side.
Am off to check my fuses!
Nice one!
Old Oct 29th, 2003, 09:07 PM   #6 (permalink)
Nameless
Nameless's Avatar
Your indicators speed up when a bulb has gone....
Check that all the bulbs are working when you indicate right, including the repeater and the dashboard.
Sounds like an overload, which may have blown some fuses and bulbs only if you are lucky.
Old Oct 29th, 2003, 09:11 PM   #7 (permalink)
GaryM
GaryM's Avatar
Send a message via Skype™ to GaryM
My guess for what is worth is that the computer has got spiked as you managed to start the car.
Get your battery fully charged first and then disconnect it from the car. Leave it for 10mins or so and then reconnect. This should cause everything to reset correctly and hopefully resolve your issues.
Let us know what fixes it?
Old Oct 30th, 2003, 07:30 AM   #8 (permalink)
TJMathias
Thanks guys.
I replaced the use for the rear wiper-it now works.
Replaced fuse for central locking-boot latch now closes but wont open again
Indicator issue not resolved.
Am off to the dealer this afternoon after work, but they are unlikely to replace any parts under warranty-hope the bill isnt too high.
Thanks for the input
Old Nov 5th, 2003, 08:20 AM   #9 (permalink)
TJMathias
took the car to the dealer, he looked at the car and told me there was a 'serious' problem with the wiring, and that the whole car would have to be taken in and wiring problem diagnosed.
****. The rear light cluster was not grounded properly, the bolt was loose, which caused the indicators to flash quick and boot not to close. Simple as tightening a bolt!
Nice one for the help!
car broken down :( matt21 Faults & Fixes 27 Mar 27th, 2007 04:42 PM
Help, my car is seriously broken! TJMathias Interior & Ice 1 Oct 29th, 2003 06:53 PM
New car has broken down!!! new_mini Faults & Fixes 5 Sep 8th, 2003 02:05 PM
