Mini Pirate
Old Nov 8th, 2003, 09:07 PM   #1
Kiwiracer
Whakataetae ki toa
Kiwiracer's Avatar
Local Time: 04:32 AM
Door Unlock issues
The "Double" pull to open the drivers' side door no longer works....Having to use remote or manually lift the post....Easy fix or a trip to the Dealer required?
BRG/W MCS Alta Pulley, Alta Intake, EVOtech ECU, 22 ml rear sway bar , Pilo Ignition pack
New Zealand   Reply With Quote
Old Nov 9th, 2003, 03:33 AM   #2 (permalink)
Bilbo Baggins
Bilbo Baggins's Avatar
Local Time: 05:32 AM
The "double pull" is a trip to the dealer. They have to access the ECU and make the change.
But, it sounds as though you have a different problem. Do I read correctly that the inside handle won't open the door? Sounds like a trip to the dealer.
'06 MCS SB/S R84s(Dunlop 5000, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 9th, 2003, 08:29 AM   #3 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Local Time: 10:32 AM
I'm confused by this one. The double pull to open the door is a mechanical action. Nothing electronic involved as far as I know.
Also Kiwiracer, how can you pull the post up? The post should drop below the level of the door if it's locked. Unless the cars are different over there.
Definitely sounds like a trip to the dealer...
It was acceptable in the 80's
Old Nov 10th, 2003, 11:14 AM   #4 (permalink)
Kiwiracer
Whakataetae ki toa
Kiwiracer's Avatar
This is only affecting the drivers side.One pull & the knob comes up but not fully disengaging the lock.Works fine with remote or interior central locking toggle............Guess something went in the handle mechanism.
Driver's side door won't lock/unlock properly MightyBoognish Faults & Fixes 1 Sep 20th, 2007 03:41 PM
driver's door doesn't unlock... mini_macky Faults & Fixes 6 Jul 3rd, 2007 01:35 PM
Question on Auto door unlock with ignition off RedMCS Faults & Fixes 4 Oct 14th, 2005 02:26 AM
Driver door will unlock and lock only manually, with key only VWY Faults & Fixes 1 Jun 8th, 2005 05:23 PM
Door won't unlock from the inside nullspace Faults & Fixes 7 Nov 11th, 2002 01:45 PM
